1986 4runner 22re rebuilt HELP!
Old 02-20-2013, 07:55 AM
sr5joser's Avatar
I have a spun bearing and im about to order a rebuilt kit but when I look up the kit asks for bore size and piston size and all the internals im a newbie and would use all the help necessary.. Thanx for the help anyone
Old 02-20-2013, 08:29 AM
j2the-e's Avatar
How many times did you post this? You will probably need the engine apart to determine sizing of what you need. And is the crankshaft useable? Probably not if you spun a bearing. I would take the crank to a reputable machine shop for inspection and machining if necessary. You cant just order parts. Some years, Toyota used a different size bearing in every journal. They stamp the sizing on both the block and the crank. Then they have a formula that uses the journal size with the block size to determine the correct bearing to use, if the crankshaft has not been machined
Old 02-20-2013, 09:40 AM
BamaYota1's Avatar
Can't order the rebuild kit without motor taken apart and everything measured. Sorry.
Old 02-20-2013, 10:01 AM
bruno4turbo's Avatar
label EVERYTHING... especially vacuum lines... when i did my rebuild my dad helped me and he didn't label anything... pretty fun figuring what he took apart out... but yea you need to take it apart prior to ordering...
Old 02-20-2013, 12:05 PM
sr5joser's Avatar
Thanks guys all of this has helped a lot. Thanks for your knowledge
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1986 4runner 22re rebuilt HELP!
