16" Rim to Fender after BJ Spacers
Old 07-14-2007, 10:51 AM
creeve4's Avatar
I just installed a set of 1 1/2" BJ Spacers on my 4Runner. I have Downey 26mm torsion bars. I let all the tension off the torsion bars, but I'm still sitting 16" from the top of rim to bottom of fender. I do have manual hubs, so the CV's are not turning 95% of the time - only when I'm off road. Is this 16" going to be too great? Smaller torsion bars? Any suggestions?
Old 07-14-2007, 12:50 PM
FredTJ's Avatar
Don't know if 16" is going to "be too great".
I suppose that you could put the front up on jack stands and fully cycle the front axle while turning it and check for CV joint bind.
Smaller (as in stock OEM size) t-bars would certainly help.
By going with the 26mm bars you've really increased the front spring rate, which is not only providing some lift, but will also effect the ride. It'll be a stiffer ride.
Fred
4x4YOTA
08-23-2016 09:08 AM
live4soccer7
05-11-2016 06:52 PM
89YodaRunner
09-30-2015 02:18 PM
Cycles
09-29-2015 06:37 AM
crash813
09-27-2015 07:15 AM
Quick Reply: 16" Rim to Fender after BJ Spacers
