16 inch rims on 86 2WD Pickup
Old 03-22-2016, 06:34 AM
karlm-c's Avatar
Hey everyone,
I have the stock 14" rims on my truck now, but want to get a good set of either full summer tires or some light AT truck tires, and there are way more options for 16 inch rims than there are for 14". I want to get a new set of just cheap steel wheels, but of course am having a hard time knowing if they'll work or not.
These are the ones I've found:
http://www.summitracing.com/parts/rnb-939-107
They seem like they'll fit, lug pattern is the same and center bore is 73mm, so will fit on the 60.1mm (I think thats the stock hub size).
I am thinking of maybe a set of these:
https://www.pepboys.com/tires/detail...T/945378/00238
or something a bit more conservative like these:
https://www.pepboys.com/tires/detail...r/315698/00238
Other than that, it seems like they'll fit fine but just wanted to see what all of you think!
Thanks!
Old 03-22-2016, 07:51 AM
osv
osv's Avatar
17" is the wheel size to get if you want the biggest selection in tires.
that said, the last time i looked at 14" tires, they were the cheapest option.
i usually buy tires from discount tire, using those coupons that come up regularly.
Old 03-01-2020, 02:59 PM
YOYO_TOYOTA's Avatar
I have an 80 model 2wd with 16x8 20mm+ offset mst mt-01 bronze rims and 1 inch wheel spacers with bfgoodrich k02 tires sized at 215/65/16 and they only rub if i'm turning hard and hit a bump or flex the front suspension. But for every day driving on the road it looks great and rides great and has almost no road noise !!​​​​​​​
The following users liked this post:
swampedout (03-29-2021)
Old 03-24-2021, 06:49 PM
Nativewrights's Avatar
Doing the same setup with 215/70/16 hopefully it fits
Originally Posted by yoyo_toyota
i have an 80 model 2wd with 16x8 20mm+ offset mst mt-01 bronze rims and 1 inch wheel spacers with bfgoodrich k02 tires sized at 215/65/16 and they only rub if i'm turning hard and hit a bump or flex the front suspension. But for every day driving on the road it looks great and rides great and has almost no road noise !!
Old 03-27-2021, 04:45 PM
Help!
Needed a bit of help with my setup! I’m running the same rims with the 73.1 bore on my 89 pickup and it doesn’t fit over in the front. Is the 1 inch spacer necessary to push it off the hub?
karlm-c
02-19-2016 04:15 PM
2003mikem
12-28-2012 02:47 PM
Mark in MD
05-24-2007 06:49 AM
BayArea111
03-03-2007 10:44 AM
xonetruthcrewx
03-08-2005 04:02 PM
Quick Reply: 16 inch rims on 86 2WD Pickup
