15 degrees advanced?
Old 06-14-2009, 11:16 AM
bayou yota's Avatar
timed my 94 22re to 5 degrees with the computer jumped and when i take out jumper wire it shows 15 degrees advanced, thats seems to much, anyone have any ideas? also my temp gauge seems to be working correctly but semms like the engine compartment is way to hot, you can't even hold you hand on the hood,please i need help, i'm scared to drive it!
Old 06-14-2009, 12:46 PM
corax's Avatar
with the ECU jumpered the timing will be less, pull the jumper off and it goes into active timing control instead of the failsafe minimum you see with the jumper in place
SoCal_Todd
10-29-2015 05:52 PM
tinigunner11
08-14-2015 01:19 PM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
Quick Reply: 15 degrees advanced?
