14 vs 18 inch magnaflow - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 04-09-2011, 04:53 PM   #1
It's time to replace my rusted out LC eng muffler which is a 2.25" dia 14" body magnaflow. I would like to go to something a little bit quieter. I am thinking 18" magnaflow. Will there be much difference in sound and performance between the 18" and the 14"?
My vehicle is a 85 4Runner 22RE stock, with LC header, hi flow cat and 2.25" tube.
Thanks
Chris
ccannon222 is offline   Reply With Quote
Old 04-09-2011, 05:17 PM   #2
peow130's Avatar
Probably be quieter.
peow130 is offline   Reply With Quote
Old 04-09-2011, 09:21 PM   #3
matt92yota's Avatar
the 18" will be a little quieter and will probably have a deeper tone to it
matt92yota is offline   Reply With Quote
Old 04-10-2011, 05:13 AM   #4
Elton's Avatar
yea id go with a 18'' from looking at there site it appears to be center in offset out which would be part #12256 http://www.ourdealsrock.net/256-12256.aspx there on sale for 70 dollars shipped cant find it cheaper !
Elton is offline   Reply With Quote
Old 04-10-2011, 02:57 PM   #5
Quote:
Thanks for the info. One more question. My current exhaust is 2.25". The link you posted is for 2.5". Was that a mistake, or should I get the larger inlet/outlet size so I can slide my current pipe inside of it then weld?
Thanks for the help.
Chris
Old 04-10-2011, 03:10 PM   #6
camo31_10.50's Avatar
no get the 2.25 inch one, then when your shop welds it on..have them expand the end a bit and slide it on...1/4" gap is a little big to be welding up..alot easier to do it with the 2.25"
my 14" magnaflow is quiet dang thing....i wanted somethin with some rumble to it lol...i don't even have a cat!!!!!
camo31_10.50 is offline   Reply With Quote
Old 04-10-2011, 03:46 PM   #7
SpecialScottie's Avatar
I have a 18 inch magnaflow on my 85 runner and it sounds like a rice rocket. Id like to replace it with something else. Just a heads up
SpecialScottie is offline   Reply With Quote
Old 04-10-2011, 04:15 PM   #8
matt92yota's Avatar
thats why i just went ahead and straight piped mine lol
Old 04-10-2011, 04:17 PM   #9
Thats what I was thinking. I have pipe expanders and have used them in the past. I'm planning on welding it up myself as I want to redo the location of the rear pipe.
Chris
Old 04-10-2011, 04:18 PM   #10
Quote:
Thanks for the heads up. My 14" one has a nice rumble at idle, but gets a little to ricey and loud above 3K for my taste. Hopefully the 18" won't be any worse.
Chris
Distance vertically between oil pan and highest part of axle housing? live4soccer7 84-85 Trucks & 4Runners 3 05-11-2016 07:52 PM
Somewhat Basic Questions (89 PU, 5 SPD Manual, 22RE) kbpickens Newbie Tech Section 5 10-02-2015 04:37 PM
1991 toyota pickup build Brodetski 86-95 Trucks & 4Runners (Build-Up Section) 0 10-01-2015 12:50 AM
Opinions needed... Rickstwowheels 86-95 Trucks & 4Runners 7 09-29-2015 03:23 PM
newb looking for help. 91 4runner lift to fit 40in tires myotherrideisayoshi 86-95 Trucks & 4Runners 1 09-29-2015 06:41 AM
Tags
06, 11, 14, 18, 18in, 22, difference, dr, flow, good, inch, magna, magnaflow, sound, tacoma, tacomas, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
