12v Power outlet question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-05-2008, 11:27 PM   #1 (permalink)
Red3.slow's Avatar
Send a message via AIM to Red3.slow
I've searched and searched for this and have found no definitive answer. I've done the 12v outlet mod in the tech section (in my own way at least). But I really need to have the stock 12v outlet a constant source. I've found my self on several occasions on the scene of a car wreck or what not and I really emergency lights to stay on with out my keys in the car. But my lighting is plugged in to the 12v outlet or powered by a relay that is on a switch powered by the 12v outlet circuit. Can anyone help me out?
__________________
-Miles
-Firefighter/EMT
T.E.A
Taxed Enough Already
Red3.slow is offline
Old 02-05-2008, 11:30 PM   #2 (permalink)
apalmer1's Avatar
Why not just pull the outlet out and cut the hotwire then run it directly to B+
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress.
85 pickup, 327sbc, truggy, in progress.
86 mazda b2000 street queen haha.
92 mazda B2600i 4x4 absolutely mobs.
81 ford bronco drinks gas
90 mazda mx-5 all original.
when in doubt, tach it out.
apalmer1 is offline
Old 02-05-2008, 11:31 PM   #3 (permalink)
stormin94's Avatar
I don't think it would be too hard to direct connect to the battery, and run a simple fuse, and a toggle switch. But if that's not what you are talking about, then I don't know. Electrical isn't really my thing.
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 02-05-2008, 11:34 PM   #4 (permalink)
apalmer1's Avatar
Yea stormin has a good point to. If you wanted to you could make it an option to toggle that outlet between constant and keyed. Just get a toggle switch and put it on the power wire to that outlet. on that switch have one leg connected to the regular wire that comes from the keyed relay controlled side, then run a wire from another leg all the way back to the battery, and put a 10-15amp fuse somewhere in series with it. then connect the other side of the toggle switch to the cord that runs into the outlet.
Boom, presto chango.
__________________
apalmer1 is offline
Old 02-05-2008, 11:48 PM   #5 (permalink)
apalmer1's Avatar
heres a quick wiring diagram for it, hope it shows up.
__________________
apalmer1 is offline
Old 02-06-2008, 12:29 AM   #6 (permalink)
Red3.slow's Avatar
I get where your going, sounds like what I should do. What about the whole circuit including the fuse block to.
__________________
-Miles
-Firefighter/EMT
T.E.A
Old 02-06-2008, 12:34 AM   #7 (permalink)
apalmer1's Avatar
Not sure exactly what your asking on that last post. Do you mean what happens on the other side of that fuse block to make it keyed or...?
__________________
apalmer1 is offline
Old 02-06-2008, 12:40 AM   #8 (permalink)
Red3.slow's Avatar
I need the fuse for the 12v outlet to have power constant to because I have a fuse tap for a switch for other misc emergency lighting. I might just walk away from this tonight because I'm tired
__________________
-Miles
-Firefighter/EMT
T.E.A
Old 02-06-2008, 01:10 AM   #9 (permalink)
stormin94's Avatar
Quote:
That's what you'll get if you wire it with the toggle switch. I had some fog lights like that. It didn't matter if the car was on or off, keys, no keys, it was all the same.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Old 02-06-2008, 01:18 AM   #10 (permalink)
apalmer1's Avatar
yeah i included a seperate fuse for just that outlet in the diagram on the leg that runs directly to the battery, there is already a fuse on the keyed leg so thats not an issue. If you wanted to wire all of your emergency things in this way you could always just use an auxilary fuse block, and then use a switch to controll weather that entire block receives constant or keyed voltage. To do that though you would need to use a switch and a relay because you would need more power than the original power outlet wire could handle.
its been a long day for me also, i was in the shop from 8am to 10:30pm, and its 1:15am here now, but i cant seem to sleep for some reason. If you wana sleep on it and figure it out later you can PM me if you have any questions
__________________
apalmer1 is offline
Old 02-06-2008, 01:37 AM   #11 (permalink)
stormin94's Avatar
And be grateful that at least your 12V outlet works at all...unlike mine. I've gone over that thing with a voltage tester soo many times, and I haven't found the problem yet. I'm guessing it's the ghost of Toyota's past.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Old 02-06-2008, 11:34 PM   #12 (permalink)
apalmer1's Avatar
Quote:
why not just replace the whole thing? its a positive, and a ground - like 10 bucks at any autoparts place for a new outlet with pigtail
__________________
apalmer1 is offline
Old 02-06-2008, 11:49 PM   #13 (permalink)
stormin94's Avatar
Quote:
Because I am lazy.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Old 02-07-2008, 02:53 AM   #14 (permalink)
flatland4runner's Avatar
Because I am lazy.
here here brother
__________________
'91 4Runner SR5- 3.0 -5spd-Aisin Manual Hubs-ISR mod
flatland4runner is offline
Old 02-07-2008, 11:06 PM   #15 (permalink)
stormin94's Avatar
Because I am lazy.
and I'd rather bitch about it than fix it........for now.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Where to wire a 12v outlet? Battery only? Hugo 95.5-2004 Tacomas & 96-2002 4Runners 12 09-27-2007 05:17 PM
12v power outlet question sdstud212001 95.5-2004 Tacomas & 96-2002 4Runners 20 08-12-2006 11:11 PM
12V outlet caps garrett1478 95.5-2004 Tacomas & 96-2002 4Runners 4 08-09-2005 01:19 PM
NEW MOD - 12V Power outlet in console ManyMods 95.5-2004 Tacomas & 96-2002 4Runners 4 08-15-2003 07:32 PM
Easy extra 12v outlet Corey 95.5-2004 Tacomas & 96-2002 4Runners 6 08-26-2002 07:46 AM
2009 InternetBrands, Inc.
