1" lift blocks?
1" lift blocks?
I have a 1990 pickup, regular cab, 4x4. The rear end sags about 1" lower than the front. I know it's not much, but it bothers me. Does anyone know if 1" lift blocks exist? I can only find ones larger. Or is there a better solution?
Thanks,
Josh
Thanks,
Josh
the add-a-leaf would still definately be the better way to go. blocks add extra stress to the suspension system, and only mask the problem of worn springs.
My local auto parts store sells add a leaf kits that add a partial leaf above the leaf pack, on the front half. Online, I've found some that would actually add another leaf to the pack. Any thoughts on one vs. the other? Thanks
Someone will correct me maybe if I'm wrong. But I think the longer leaf would usually give a softer ride, a shorter leaf will need a higher spring rate and be more stiff.
I need new springs it's like riding a skate board on a cross cut sidewalk, ka-thunk-ka-thunk-ka-thunk.
Well, I got some add-a-leafs and finished installing them the other day.
The driver's side seems to be about where I hoped it would be. When I got that spring pack apart, one leaf was broken (the second one down). I had a replacement leaf made at a local drivetrain shop. So now it's three old leaves, one new leaf, plus the new add-a-leaf. I like how it's sitting.
The passenger side, however, is too high. The entire passenger side spring pack was replaced within the past couple years, before I bought the truck. It did not sit higher than the driver's side before the add-a-leafs, but with the add-a-leafs it is very noticeably higher. I am hoping that it will settle after a couple months, but I do question whether it will settle enough to match the driver's side. Any thoughts on this? Thanks
If it doesn't settle, maybe I'll just take the add-a-leaf out of the passenger side and see what I've got then. Stuff around here rusts so much....it was quite a chore to get that driver's side pack out and the center pin out. A lot of Q.T. with the angle grinder. Thanks for the idea though.
a little late now but a zuk mod with some jeep springs would have been the easy and cheap route to go, and you could have gotten both sides even. might be worth looking into, sucks you already bought the add a leaf kit though.
After driving the truck around some, it seems like the suspension has chilled out. Maybe I should not have posted so soon about the one side sitting higher. I think it's all good now.
Thanks to the guys above who suggested going with the add-a-leaf. It really did what I wanted it to do, and it's nice to feel like the truck could haul a little extra, if it's ever needed.
