#1 cylinder trouble
#1 cylinder trouble
when I pull spark plug wire off of cylinder one there's no change. Injector is popping off, fire on the plug with it out, but something isn't right ?
It's usually common courtesy to wait 24 hours before bumping a post. Considering that it appears to be a hot topic for you, I'm going to assume you have searched the forums, even using Google to help, right? If you didn't take that time for that, rest assured there are plenty of search results and such from Yotatech and Google telling you what you should check if you pull a plug wire and the idle doesn't change.
