1" body lift hardware length
Hey guys
I've been looking all over for info but cant find the information I need. Im installing a 1" BL that i made from a HDPE rod cut into pucks. I realize 1" BL is not really much but I just need it for tire clearance. At any rate, what length hardware should I pick up? I know the HW is different at different point on the body and I would just take them off and head to the store but Im limited on transportation, as in this is it.
Any info is greatly appreciated. Thanks!
I've been looking to do a 1.5 inch body lift and been trying to figure out what changes I need to make to the vehicle other than the direct lifting hardware. I found mixed results, so I'm still not sure what exactly is required. Come on forum, give some absolute answers
realifedog, what clearance issue are you trying to solve? I want some more space between firewall and engine/exhaust crossover. I'll be adding a 2 inch or so body lift in the future.
Not a bad idea Robert, can't believe I hadn't considered that.
Drew, I am definitely reluctant of running stock HW. I would pick up the 4crawler kit but I already have the pucks cut and drilled so all I'm lacking is ~$25 in HW. trying to save my pennies...
09-04-2015 09:27 AM
whereAreMyPants
07-22-2015 03:32 AM
