YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-03-2008, 02:52 PM   #1 (permalink)
Derek92's Avatar
why is my 22re idling so high?
My yota wont idle under 1100rpm. I just did a valve job and when i put it back together its idling super high. I tried adjusting the screw on the throttle body but i can only get it down to 1100rpm. Does anyboby have any ideas?
Thanks, Derek
Derek92 is offline
Sponsored Links
To remove this ad, register today!
Old 08-03-2008, 04:06 PM   #2 (permalink)
94toy4x4fever's Avatar
Is you timming at 5*? If you timing is off you can mess with the screw on the intake and it wont do anything. I would say if you have tryed to play with the screw and its still idles at 1100 then my guess would be timing! So jump the dig port and set timing at 5* and see what you get! you will have to readjust the idle screw after you time it!
__________________
94 toyota pickup.
22re w/ RV cam
pacesetter header with flowmaster 40 series muffler
K&N cold air
31" cooper stt's
bedlinner
87 toyota 4runner.
22re
33" nokian vatiiva M/T'S
4inch lift
things to do:
40 series flowmaster
gears
custom front and back bumpers
sliders
lockers
SAS one of these days after the IFS cant take it any more!!!!
94toy4x4fever is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Idling High 89OldBlue 86-95 Trucks & 4Runners 1 06-30-2008 05:13 PM
idling high 89OldBlue 86-95 Trucks & 4Runners 2 06-21-2008 05:18 PM
idling high first gen. yota Pre 84 Trucks 3 12-12-2007 05:45 PM
Idling too high MIKE B Maintenance & Repair Archives 3 04-10-2005 04:47 PM
I'm idling high!! ravencr 95.5-2004 Tacomas & 96-2002 4Runners 12 02-01-2004 11:34 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
