Weber carb ?
Weber carb ?
I am running a brand new weber carb set up on my `85.This thing loads up real bad with fuel.I took the carb off to check some things and there was a lot of raw fuel in the intake.That would explain why it`s running so rich.My question is;what would cause this?I have the mixture screw set at 1 and half turns out.Does it have something to do with vacuum lines?Am I missing something here?Thanks for any help.
i recently put a weber 32\36 on my 79 truck. i also installed a pressure regulator, its adjustable and i have it set at 3.5 psi right now, seems to be fine. i didnt try to run it without a regulator, from what i read the webers need pretty low pressure. if i recall the regulator was about $20 from the local parts shop.
i wouldnt think the dist. would affect it if it was from the same engine from an 84.
Toys4parts
09-26-2015 01:56 PM
