YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-01-2008, 05:14 PM   #1 (permalink)
taconasty's Avatar
vented rotor question
i am doing the vented rotor swap and have run into the issue with the wheel studs. i bought the ones recommended on the pirate4x4 and they are not going in. i have a small 12 ton press and it wouldn't even get them in all the way. what are you guys with this swap running for studs?
thanks
taconasty is offline
Sponsored Links
To remove this ad, register today!
Old 09-01-2008, 05:38 PM   #2 (permalink)
slacker's Avatar
my swap was on a 83 model year ..
no problems with the studs ...
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5
MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 09-01-2008, 05:41 PM   #3 (permalink)
taconasty's Avatar
did you use studs for a landcruiser?
Old 09-02-2008, 07:20 AM   #4 (permalink)
slacker's Avatar
the stock 79-83 studs .. which , i'm not positive .... but i'm sure there the same as the 84-88's ?
EDIT:
actually , arnt the landcruser the same as well ?
__________________
83 Trekker SR5
MY PAGE
NEW Trekker forum
slacker is offline
Old 09-02-2008, 10:24 AM   #5 (permalink)
taconasty's Avatar
well the land cruiser studs have a knurling that is a bit further down to compensate for the rotor thickness. this is from what i gathered looking at them side by side. my new studs are about .015 thicker, which is apparently too much. i am having one hell of a time getting these in. it shouldn't be this hard, i guess i have to borrow a car and order oem. i'm pretty fed up with working on this truck.
Old 09-02-2008, 01:38 PM   #6 (permalink)
taconasty's Avatar
well i took them to napa and their press had no issue with them, the guy said they are going in tighter then normal. only charged me 5 bucks too. i gave him 10, and if i had a 20 i would have happily gave it to him. so my pos 12ton press is going back for a 20ton. oh well, on to the reassembly.
thanks
Old 09-03-2008, 02:42 PM   #7 (permalink)
Post the part number of the studs you used and what rotors you used. Please
854x4 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
94 Pickup Rotor Question WV94TOY 86-95 Trucks & 4Runners 28 01-22-2008 09:09 AM
Brake pads and rotor question mkgarrison5 95.5-2004 Tacomas & 96-2002 4Runners 18 08-23-2007 11:43 AM
rotor removal question i_rifiyou 86-95 Trucks & 4Runners 4 01-15-2006 03:21 PM
cap and rotor for 3.0 question SolidDigital 95.5-2004 Tacomas & 96-2002 4Runners 5 06-23-2004 05:24 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
