YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-30-2006, 09:58 AM   #1 (permalink)
Timing Chain Cover
Can anyone tell me what all I need to remove to get the timing chain cover off of a 84 22r. It has grooves in it and it is leaking. Also what all should I replace when I have it off? Can I get those parts at a local autoparts store?
Twigger is offline
Sponsored Links
To remove this ad, register today!
Old 06-30-2006, 12:09 PM   #2 (permalink)
4Hummer's Avatar
Replace the Water pump, oil pump, and timming chain.
Look up Ted at engine builder for the best parts and prices
__________________
Michael
1991 4Runner 22RE.
CHOP
www.obsessiveoffroadclub.com
4Hummer is offline
Old 06-30-2006, 02:06 PM   #3 (permalink)
Well do I have to pull the head and the oil pan like the manual states?
Twigger is offline
Old 06-30-2006, 04:39 PM   #4 (permalink)
no you should only pull the oil pan.... just be carefull with the head gasket when you put the cover back on, it can bind on th etop of the cover....
use gasket sealer to hold the timing chain cover's gaskets on each side of the cover. im not talking about the silicon permatex in a tube but teh stuff you brush on the gasket to help it stick in place... i think its called gasket cement or something. after you get the gasket on the timing cover use gray permatex on the back side of the gasket that goes to the block... dont use too much tho.
dont over torque the tensioner bolts or any of the timing cober bolts. use grease to hole the oil pump o ring in place while you put the oil pump on, and be sure that the o ring doesnt come out of the groove or it will spray oil everywhere...
spirtlanimilbus is offline
Old 07-03-2006, 02:56 PM   #5 (permalink)
Alright, thank you very much for the information.
Twigger is offline
Old 07-03-2006, 04:42 PM   #6 (permalink)
kyle_22r's Avatar
i don't recommend using any kind of RTV on gaskets any more. i've been using the permatex "high tack" gasket sealer in the can and it seems to work very well on all types of gaskets. if RTV gets loose into an oil passage it can starve a bearing to death and fry your engine.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 07-07-2006, 09:01 PM   #7 (permalink)
03_4x4Runner's Avatar
The head can stay on, but there is still a bolt through the head that holds the cover on.
You may want to give LC Engineering a call, about their dual row timming chain conversion, it has metal rails, that wont let the chain rub against the cover after they are worn out
__________________
2003 4Runner SR5 4x4 V8
Galactic Gray Mica - Apearence Package
Husky Liners, Double Decker, 17" Wheels
1991 Jeep Wrangler Islander 4.0 5-Speed
03_4x4Runner is offline
Old 07-09-2006, 04:04 PM   #8 (permalink)
So I have the crossmember unbolted and out of the way but the pan will not come out. What else do I have to remove to get the pan all the way out?
Twigger is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
timing chain cover THEYOTAKID Engine/Tranny/Parts 6 03-19-2007 08:32 PM
timing chain cover gaskets ssupercoolss 86-95 Trucks & 4Runners 2 03-15-2007 12:10 PM
timing chain cover and oil pan-need some help old4runner 86-95 Trucks & 4Runners 9 01-30-2007 03:21 PM
size of bolts for timing chain cover. needayota 95.5-2004 Tacomas & 96-2002 4Runners 8 03-28-2005 07:51 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
