Timing chain broke, bent valves certain? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-17-2009, 08:33 PM   #1 (permalink)
Andrew666's Avatar
My 84-89 truck was idling in the driveway and died. No unusual sounds, bangs or otherwise. Such a quiet death I thought for certain it was electrical. Long story short, I pulled off the timing cover and found a broken chain dangling off of the cam gear. One of the sproket teeth on the crank broke off, but the long chain guide bit the dust too. Could this be to blame for the busted tooth or do I most certainly have bent valves? I opted to pull the chain cover without pulling the head off so far...any tests I can do at this point to ensure good valves?? Thanks
Andrew666 is offline
Old 12-18-2009, 06:26 AM   #2 (permalink)
toyotabull's Avatar
A leak down compression test might do it but you, will have to have the timing lined up and another chain on there.You are better off just pulling the head and taking it to the shop and having it redone and checked. How many miles are on it?
__________________
1985 x-cab 20R-22R 33-12.5
www.whenshtf.com
I would rather explain to the judge why my 16 year old daughter shot an intruder, than explain to the jury why it took 5 days of torture for my daughters killer to die
"If you are mad as hell and aren't gonna take it anymore, grab your rifle and head outside. If you're the only one with a rifle screaming like a maniac, go back inside. It isn't time yet."
toyotabull is offline
Old 12-18-2009, 02:06 PM   #3 (permalink)
Andrew666's Avatar
178k, probably a good idea. I have a "new" head on the bench, just needs to be checked out at a machine shop.
Old 12-18-2009, 04:01 PM   #4 (permalink)
interested2meet's Avatar
back all the valve adjusters off and do a leak down.
interested2meet is offline
Old 12-18-2009, 06:25 PM   #5 (permalink)
Andrew666's Avatar
I am usure about what a "leakdown test" is..
Old 12-18-2009, 10:00 PM   #6 (permalink)
Tracey98277's Avatar
the 3vze is a non interference engine, meaning that if you break the belt the valves have enough clearence if you have a stock cam, idk about the 22-re... no clue.
__________________
myspace
Quote:
Originally Posted by vital22re View Post
first you're giving jack 1.5 bjs now you want me to winch off your snorkel.. you're a cool dude... but you got issues... say hello to your mother for me
Quote:
Originally Posted by peow130 View Post
yeah.
reverse reverse + low, would be an epic crawl ratio of epic proportions..
Tracey98277 is offline
Old 12-18-2009, 10:55 PM   #7 (permalink)
91Toyota's Avatar
22re + timing chain break = destruction
A leak-down test = Is a test used to tell where compression (air in the cylinder) is leaking from. Close the valves, put the piston your testing at the top, fill with air, and look at the gauge and see if its leaking (little is normal) and if you can hear air hissing out of the intake, suspect intake valves. Hissing out of exhaust, then the exhaust valves. Hissing out of the oil cap, then rings.
__________________
1983 Toyota Tercel 4wd 62hp
1999 Dodge Cummins 3500
91Toyota is offline
Old 12-18-2009, 10:56 PM   #8 (permalink)
91Toyota's Avatar
It most certainly destroyed the pistons and bent the valves.
__________________
91Toyota is offline
Old 12-18-2009, 11:23 PM   #9 (permalink)
may have a chance if the idle was not to high
herpestes is offline
Old 12-18-2009, 11:30 PM   #10 (permalink)
91Toyota's Avatar
I doubt it. 750rpm...valves and pistons slamming each other.
__________________
91Toyota is offline
Old 12-19-2009, 06:30 AM   #11 (permalink)
slacker's Avatar
22 series engines are absolutly interferance engines .. and valve stems are super easy to bend ... I would lay money on 2 bent valves , and pistons will be fine
I have bent a valve turning the crank over by hand (socket & ratchet)
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5 CURRENT BUILD
My home page MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 12-19-2009, 07:13 AM   #12 (permalink)
snobdds's Avatar
Quote:
Originally Posted by Andrew666 View Post
My 84-89 truck
Where can I get one of those???
__________________
1988 4x4 Pickup 22 RE. Stock-ish, But oh the places it's seen.
snobdds is online now
Tags
1991, 31, bend, bent, break, broken, chain, exhaust, guides, rhino, spot, throw, timing, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
