throttle cable 21 inch
I cannot find the throttle cable to go on my 22r 2wd truck. I have looked high and low and have searched all the threads that may pertain to my situation and have not found a solution. The 4runner is down with a rear end issue and need to get to work to afford to wheel. I cannot find a 21 inch cable anywhere. i tried a previous solution which was a 93 4runner cable and it also is 38 inches long. please help i am using bailing wire at the moment and it is sketchy. no noobie here have rebuilt the engine and transmission and the truck is in great shaoe just waiting on the straight axle parts to let it join in the fun as well. i seem to be having trouble even finding a part number in the oem stuff to look for it. i still am not sure if it is even called a accelerator cable or throttle cable even and that is after a few hours of research. Thank you for your time if you can or cannot help and toyota is the ˟˟˟˟!!!
