Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
temp gage semi broke
my temp guage will be on then just fall abck down to the rest post. i dunno if there is a sensor to check or is there is a way to see if its the guage. any ideas?
| Sponsored Links |
#2 (permalink) |
The Factory Service Manual has test procedures for tboth the gauge and the sender. Might check that the wire is plugged securely into the sender, I had a problem with my oil pressure gauge dropping to 0 every now and then and it was a bad connector on the sender. I rebent the metal inside the connector shell to make it fit tighter and it has been fine since.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
i have the haynes manual.. is that the one that has it? where is the sender located?
#4 (permalink) |
There's a couple temp senders on the engine. Check each one's connector. There are at least 3 thermo sender/sensors on my 85 22re.
Here's an 1985 Service Manual Right click on this link and choose save target http://www.ncttora.com/fsm/1985/1985FSM.pdf Last edited by pcmentor : 09-10-2008 at 07:21 AM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rpm Gage | Mexifoo | General Electrical & Lighting Related Topics | 0 | 12-10-2006 01:01 AM |
| Oil Gage | keithguts | 86-95 Trucks & 4Runners | 2 | 11-17-2006 04:32 PM |
| Heat Temp Gage: Help | keithguts | Off Topic Talk | 2 | 10-15-2006 10:55 AM |
| Trany temp gage on tundra | Gearman | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-19-2003 07:32 PM |
