YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-23-2008, 12:55 PM   #1 (permalink)
nomiss05's Avatar
steering linkage problems
i bought 2" blocks fo rmy 85PU and the passenger side went on fine, no problems.. when we got to the driver side we found out that the steering linkage sits aomost on top of my stock leafs, so once we put the block on it the link hits the leaf.. the steering is all put together stupid. so how does anyone lift that truck with them setup like that?
nomiss05 is offline
Sponsored Links
To remove this ad, register today!
Old 08-23-2008, 01:11 PM   #2 (permalink)
4Crawler's Avatar
That is one reason why you don't run lift blocks on the front end. Get some lift springs. OME makes a nice 2" lift spring kit:
http://www.arbusa.com/
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-23-2008, 01:44 PM   #3 (permalink)
nomiss05's Avatar
well that makes sense.. so n oone runs blocks on those trucks? theres no way to move that arm?
if i were to run a 4" spring on my fronts do i need to re locate or change my steering in the front too?
nomiss05 is offline
Old 08-23-2008, 01:45 PM   #4 (permalink)
The other reason is that it's downright dangerous......get rid of them and lift it correctly!---------Hans
__________________
Redneck trapped in a brown man's body
Oatmeal is offline
Old 08-23-2008, 01:48 PM   #5 (permalink)
4Crawler's Avatar
With 3"-4" of lift, you can convert to crossover steering and get rid of the stock push-pull setup:
- http://allprooffroad.com/pickupsteering/17
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-23-2008, 05:40 PM   #6 (permalink)
Blocks are nothing but pure booty fab.
If you're going to lift, do it right and do it safely or don't do it all.
Fred
FredTJ is offline
Old 08-24-2008, 05:50 PM   #7 (permalink)
85toy's Avatar
o you need to read and then read some more use the search button
__________________
1984 toyota pickup extended cab 4x4
couple of mods
85toy is offline
Old 08-24-2008, 05:56 PM   #8 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Blocks on the front? Seriously?
If you can't afford to lift it right the first time, why not just wait? Is a lift really that important?
You need to save up and get some 3-4" lift springs. The Toyota steering is a great setup, but you will need a drop steering arm too. The only other option is to install crossover steering.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by 1972TLC View Post
DC, you're always #1, don't worry ;)
DeathCougar is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How Could I Make a VIDEO So you GUYS Can best Diagnose My steering LINKAGE simpsons721 86-95 Trucks & 4Runners 0 08-08-2008 03:49 PM
Steering linkage problem declipse 86-95 Trucks & 4Runners 2 07-29-2008 01:24 PM
Lookin at toyota with linkage problems 87 yota 86-95 Trucks & 4Runners 5 05-21-2008 10:05 PM
86-95 IFS steering linkage and front crossmember webilt Misc Stuff (Vehicle Related) 0 01-01-2007 07:26 PM
Steering Linkage Broke - HELP!! Bumpin' Yota 95.5-2004 Tacomas & 96-2002 4Runners 7 08-27-2003 09:13 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
