sr5 coolant gauge issue - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-18-2009, 11:13 AM   #1 (permalink)
did a search around and others that had similiar problems but no solutions. the temp gauge pegs out like 30 seconds after starting from dead cold but the truck isn't overheating. looks like some sort of common problem with sr5's?
__________________
1985 SR5 Pickup 22RE bone stock with the exception of a stereo and 31x1050x15 BFG's
Motomeister is offline
Old 10-18-2009, 11:32 AM   #2 (permalink)
vital22re's Avatar
Send a message via AIM to vital22re
you try replacing your coolant temp sending unit/sensor?
__________________
92 toyota truck 3.4 5spd 4.56 gears magna flow cat and muffler2 1/4 piping isr mod to intake 1.5 bjsfront add a leafs and 2inch lift shackles rear rancho shocks all around sitting on 265/75/r16 nitto terra grapplers
vital22re is online now
Old 10-19-2009, 11:39 AM   #3 (permalink)
where would this be located? on top of the thermostat housing im assuming?
__________________
Old 10-20-2009, 12:17 AM   #4 (permalink)
my-4x4's Avatar
you could possibly have a bad ground...
__________________
-'87 4x4 22r fairly stock.
-Thrush glasspack
-Hurculined cab floor
-SR5 Gauge swap
-'84 4x4 22r STOCK
-32x11.5 BFG M/T
-Magnaflow exhaust
USAF Confinement Officer
my-4x4 is offline
Old 10-24-2009, 09:02 AM   #5 (permalink)
Quote:
hmm, is there a easy way to check this? go from the sending unit(at the thermostat) to the gauge? kinda new to electrical troubleshooting but understand the basics
__________________
Old 10-24-2009, 09:10 AM   #6 (permalink)
874runnersr5's Avatar
Search, theres a thread. You need to get a differnt type of thermostat that has a little hole in it to allow coolant thru all the time or something along hte lines of that.
__________________
87' 4runner Sr5 : 22re : 5spd : 32x11.5 BGF Km2 : Cragar 15x8 soft 8s : TG Rock Defense Front Bumper : Sirius radio : Optima Red Top : Pioneer system : Engnbldr tchain kit : Downey 3" leafs : Diff breather : Tube doors : Bikini Top
Calgary Toyota Association
I <3 my Toyota
874runnersr5 is offline
Old 10-24-2009, 10:08 AM   #7 (permalink)
4Crawler's Avatar
Quote:
Yep:
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Quote:
TSB: 029032787 22R-E Engine Temperature Overshoot
It says:
Some 1984 pickup trucks and 1983-1984 Celica models, equipped with 22R-E engines, may experience a condition called "temperature gauge overshoot". After starting a cold engine the temperature gauge will indicate a higher than normal engine temperature for a short time just prior to the thermostat opening. After the thermostat opens, the temperature gauge will return to the normal range. A new double valve thermostat has been made available to reduce temperature gauge overshoot.
And calls for part number 90916-03070 which according to the TSB replaces 90916-03055.
Happened on my '85/SR-5 and the t-stat listed fixed it 100%.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-24-2009, 10:13 AM   #8 (permalink)
Quote:
Originally Posted by 4Crawler View Post
Yep:
its not a problem of overshooting. it goes from dead cold to hot and doesn't fluctuate at all after that.
__________________
Old 10-24-2009, 10:17 AM   #9 (permalink)
It could also be the gauges.. since the sr5 gauges arent the best...
__________________
I <3 my Toyota
Old 10-24-2009, 10:17 AM   #10 (permalink)
4Crawler's Avatar
OK, then grab the Factory Service Manual, it has a page or two of testing the gauge and the sender.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-24-2009, 10:27 AM   #11 (permalink)
wow, thanks man. never seemed to look into that section of the FSM... i think this will helm me tremendously. ill post up what i find.
__________________
Old 10-26-2009, 11:32 AM   #12 (permalink)
sending unit for the gauge is a single wire unit? it wouldn't shock me if you told me the wire going to this sensor was green??
__________________
Old 11-18-2009, 02:07 PM   #13 (permalink)
so my gauge does not ohm out properly. how do i go about replacing just the gauge?
__________________
Tags
22re, 9091603070, gauge, issue, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
