Some interesting and potentially helpful EFI conversion info - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-05-2008, 10:24 AM   #1 (permalink)
Thumbs up Some interesting and potentially helpful EFI conversion info
So, I just wanted to say hey to everyone as a first time poster of this community.
I've been through some interesting things with my 4runner project and thought I would share them.
First of all, it is an 84 4runner. My father in law gave it to me after it set for 5-6 years in a field. Frame is in good shape, body so so, and motor had bad front and rear mains and a bad fuel line. The engine started out as Carb and I wanted it to be EFI. I figured if I'm rebuilding the motor (which I wanted to do as it was setting for 6 years) then I may as well get rid of the carb. So I buy all of this EFI stuff from a guy parting out his Toyota truck.
I get everything going, get my motor pulled, replace the rear main, clean it up a lot, paint the block, replace the head bolts and head gasket, replace the timing set, put a nice cam in it, replace the oil pump and water pump and timing cover gasket, replace the oil pan gasket, and taboot go through the terrible ordeal of pulling my crank pulley bolt, everything is going great.
So a week or so ago, I go to bolt on the intake runners for the EFI manifold and the bolt pattern is completely different. My stomach sinks to my feet. I start digging through all the info I can find and then I find out that the motor that is in my 84 4runner was a rebuilt motor swap about 8 years ago and obviously not the original motor. I'm looking through everything I can find and frankly quite angry because as far as I was concerned, either my entire motor was a wash or I had to find an 83-84 head (due to the open combustion chamber, dual row timing, and intake bolt pattern). Then it hit me!
I go out in my garage with a vengeance. I compare the intake runner to the bolt pattern. AHA! There's four out of ten holes that match up...and then something else strikes me. The mating surface on the head has all of the flats for where the other six holes need to be...just no holes. I confirm that all of the ports between the head and the runners mate correctly and the two water passages mate up. After making sure of this, I knew I was in business!
I take a trip to Advance Auto and pick up their 40pc. tap and die set (the only tap I needed was the M8x1.25) and picked up some machining lube. I confirmed that a 1/4" drill bit was the best size to drill with. So I put my intake gasket in place and sharpie all of the holes that are not drilled. Then I took my drill bit and sunk it down into an all ready drilled hole and marked the depth with electric tape. Here is the most important of what I did. I checked to make absolutely sure that there was enough meat in what I was drilling into to make sure that I did not drill into a valvestem, water passage, or oil passage. Basically, this was really meant to be. Plenty of room.
I went through every mark, starting with a small pilot hole dry down to about an 1/8" and then well lubed the rest of the hole. Cleaning out all of the shavings from every hole as I went along and then filling the hole with lube and lubing the tap. The head tapped VERY cleanly!
As of now, the entire intake is on the head and every one of the holes took the correct factory torque specs. This has saved me in a huge way, both in tons of work and quite a bit of money. It cost me essentially $28 for the tap and die set and the lube. The drill and drill bit, everyone should all ready have.
I will warn everyone though! This is not for the faint-of-heart to do something like this. I was ready and willing to trash my head in attempting this. It was an absolute last resort as it was going to EFI no matter what!
The reason that I thought I would share this is I have not seen anyone else give any information whatsoever about doing this and it working. Everyone just says "Just go buy an 83-84 head...you're screwed."
If I have a chance, I'll post pics of my abomination later.
rsidner is offline
Old 06-05-2008, 05:39 PM   #2 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
i converted my 84 also, but mine has the original engine in it so the head was already drilled, the wiring is the fun part
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 06-20-2008, 12:02 PM   #3 (permalink)
Volcom's Avatar
Quote:
And the fuel tank and fuel lines
Nice work on tapping the head, more courage than I have
__________________
1984 Toyota 4Runner
EFI swap
TG 4" springs
Marlin Crawler Dual Ultimate Crawler
39.5" Iroks
Addicted Off Road 8 point cage
Addicted Off Road front bumper
Addicted Off Road
My 4 wheel drive club
http://www.rockfrogs.org
Quote:
Originally Posted by cubuff4runner
Let them puppies BREATHE!
Volcom is offline
Old 06-20-2008, 04:44 PM   #4 (permalink)
superjoe83's Avatar
Quote:
hehe, i cheated and used the original carb tank, and just put a in line pump on the frame, eventually I'm going to a fuel cell, since my factory tank seems to be loosing capacity every time i get squirrelly in big rocks
__________________
- Joe
Old 06-20-2008, 09:47 PM   #5 (permalink)
Volcom's Avatar
I have a feeling I'll be going to fuel cell as well. My stock skid is trashed but the tank is still good so far. It won't be long
__________________
1984 Toyota 4Runner
EFI swap
TG 4" springs
39.5" Iroks
Addicted Off Road
Volcom is offline
Old 06-27-2008, 04:35 PM   #6 (permalink)
Toyotero's Avatar
Nice. that's very ballsy drilling into the head... much cheaper than a new head..
Did you take the head off the engine to do it, or did you do it with it under the hood still?
You might be a the first to try this method to do a R to R-E conversion!
__________________
- El Toyotero
"I fly by ya in a foreign whip!"
FREE Toyota Factory Service Manuals ---> FSMs
Toyotero is offline
Old 07-08-2008, 02:31 PM   #7 (permalink)
The head was still on the block but it is on an engine stand.
No substantial update as of recent. I have been (ensuing laughter) working on my wiring and working on dropping/replacing my tank and fuel lines.
rsidner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
interesting 1st Gen Conversion ocdropzone Pre 84 Trucks 10 04-12-2009 02:11 PM
Honda CBX 1100: Need info on EFI conversion Neighborcat Off Topic Talk 0 06-19-2007 02:57 AM
Interesting info....85 efi tank lines/fuel presure Yoda General Vehicle Related Topics (Non Year Related) 2 10-14-2006 09:40 PM
Interesting Toyota info!! DeathCougar Off Topic Talk 5 08-21-2006 01:11 PM
interesting info on beadlocks FirstToy Offroad Tech 21 10-21-2003 11:13 PM
2009 InternetBrands, Inc.
