Skyjacker leaf springs
So, I haven't posted here in a looong while, but I've got a question. I just traded my stock rear springs for some skyjacker 6" springs (all four packs). I do a fair amount of trails and rock crawling when I go, so I'm curious as to how these will flex on the trail. These have only 3 leaves per pack, so I'm leary about removing a leaf to get the desired flex. I am curious if I can swap a factory leaf in the middle of the skyjackers to retain the number of leaves, but give it some flex at the same time. I also know I need shims to correct pinion angle, not sure how much 'shimmage' is needed though. I think I need a drop pitman arm for this big of a lift as well. Maybe longer shocks? Talk to me guys, thanks.
I'd go with cross over steering along with that 6" of lift. I think the suggested limit is 4" of lift for stock, correct me anyone if ya think thats not right.
u can get a z-link drag/link bar from the pitman to the steering arm from super lift or skyjacker..... i have 6" springs, and 2" shackles. i use a z-link..... no problems here
u wont beable to flex all that well rock crawling with skyjacker lift. u can swap the leaf for a stock but u will loose lift and weakin the other two springs. u will need shims front and rear, if the shims arent already in the leaf pack. i had to put 20* shims front and rear. and yes u will need longer shocks. i went with 10" lift shocks for my yota so the axle doesnt just hang on down stroke due to shock. but keep in mind im here in the south and do alot of mud riding and trails. NO CRAZY ROCK STUFF
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
Okay, I just tried to install these (just to see how they would sit) and they seem to be too short. My shackle has gone from stock to being completely in line with the spring. Anyone think I could use some banana shackles o fix that?
I've got rancho 5000 shocks, I think they are bigger than stock but I'm not sure. I also have already upgraded to extended steel braided brake lines.
I checked the part number on the front springs and it matched, so maybe I got 2 pairs of fronts or something. I will try to find a number on the "rears" but the paint is probably rubbed off too much.
The shackles have worked their way healthier, not quite back to stock, but they aren't vertical so that's good. They are probably healthy enough to drive on.
zlink ?
New here and need some help! I picked up an 86 truck with a straight axle conversion and 3" body lift. my front springs were flat, so i got a set at the local salvage yard. Just finished installing and didn't expect the lift! I know I will probably have to adjust my pinion angle with some shims, but my main concern is that my drive link hits the rear u bolt when the steering is turned right. the angle seems real steap. Is there a longer pitman arm or other fix to reduce the angle and fix this problem? I also need to add some lift to the rear as I am 3" high in the front now. Thanks for any advice!
Could also be the spring pack you installed is too thick. With a dropped drag link you can also consider flipping the ball stud on the driver's side steering arm (ball on top instead of below) for added clearance. Or install crossover steering and get rid of the stock setup:
- http://www.4crawler.com/4x4/CheapTri...ng/index.shtml
If you have any kind of money to spend, I'd swap to crossover steering, you already have the right steering box for it. Throw some add a leafs in the rear to try and gain some lift.
crossover
Thanks, I was checking that out this am as well as the drag link. I am afraid even changing the angle will not give me the clearance I would like to have. I think it could still hit given the right circumstances. If it mounted to the top of the steering knuckle, that would be the trick.
