| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
rough country lift kits
#2 (permalink) |
i'm running their front springs 3.5 lift. they were way stiff, so after about three times out, i took two bottom springs out and replaced them with three thinner springs, rides MUCH better, and flexs 10 times better.
__________________
91 SAS, 22RE, 529's, 35" swamper tsx's, Lincoln Locked Front and Rear, Marfield outers, 8000 lb Warn, passenger side OH HELL handle and the skinny pedal with a magnet on the bottom. 94 stock, 262k miles, 31" bfg Mall terrains |
#3 (permalink) |
Depends on what you want. You just wanna have a good lookin lifted daily driver, it would probly be ok. If you ever wanna carry weight or go wheelin, i would spring for somethin a little better.
__________________
. . . I said lie, for me lying under a process tree . . . . |
#4 (permalink) |
I have them on my 83 they flex ok but there name is true to ride quality...What thinner springs you use to soften the ride it might be worth it
__________________
NEW*** 1985 lifted locked dual cases bumpers and sliders now my daily! 1985 Stock Had to do head gasket and some other minor things left. 1983 Hilux 4X4 SR5 4 Sale 3" Rough Country Lift 32" Goodyear Wranglers. Custom bumpers being made!! 1995 4Runner 4X4 V6 SR5*****TRADED |
#5 (permalink) |
i looked at mine again, i'm only using the main spring from rough country, and three other thinner springs below that. it rides pretty dang good, and flexs well.
__________________
#6 (permalink) |
where did you get the other springs from? can they be pulled from the stock ones?
#7 (permalink) |
yes, i used three stock toyota front leafs, but don't ask which ones. i just stacked them according to length, shortest on bottom of course. after all this was said and done, i'm still sitting about 3" over stock. i'm using all-pro hy steer, and have plenty of room between the tie rods and springs
__________________
#8 (permalink) |
I installed the Rough Country 3" lift kit with all new springs on my 84. The ride is not bad at all. One of the things I did notice is there are no bushings for the shackles at the frame. If I am removing the shackles, I might as well put in new bushings. The bushings used for the shocks at the front axle did not fit very well. I would also suggest new, longer brake lines. The install took me a day to do. Make sure you have stands high enough for the frame to accommodate the arch of the springs. You will NOT need a new drag link. The stock one works just fine. Also, make sure you have PB Blaster. The price I paid was well worth it! The kit came with 4 springs, 4 shocks and various hardware components. I believe I paid about $300.00 less shipping about a year ago.
__________________
84' 4x4, xtra-cab, white, 3" lift, 33's, 22r carb. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rough Country Lift Questions | 1992-4r | 86-95 Trucks & 4Runners | 26 | 04-18-2009 11:01 AM |
| got rough country lift in friday | fireman1559 | Offroad Tech | 21 | 01-05-2009 03:13 PM |
| Rough Country 3" Lift | 85runnr | 84-85 Trucks & 4Runners | 6 | 06-16-2008 05:58 PM |
| 89 4 runner/ rough country lift part#??? | 99lspwr | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-07-2007 05:18 PM |
| Rough Country 6" lift | kpooch75 | FJ Cruiser | 20 | 01-06-2007 11:58 AM |
