Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Rebuilding a rear diff
We discovered that the rear diff in my son's '85 was shot (a lot of metal chunks and next to no teeth), so we're getting ready to order some parts for it to have it rebuilt and I have a few questions.
Does this look normal on the ring gear case? I'm not sure if it was damaged or if it was manufactured that way. Do you think it sould be replaced? ![]() Here's a pic of the pinion gear. ![]() Thanks. ![]() |
| Sponsored Links |
#2 (permalink) |
Thats pretty bad dude! Does this truck have a lift on it that it came out of? This can be caused by the wrong size driveshaft
I had similar marks on the carrier but not on the pinion.
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
#3 (permalink) |
I'm about to remove both diffs from my 85. The rear has about 150k on it but the front must have less than 2k (rarely used 4WD). I'm installing TRD elockers front and rear.
If you want one or both of these (stock 4.10 gears) then send me a PM. I wouldn't rebuild what you have as used diffs are pretty reasonable.
__________________
1985 4Runner 1997 FZJ 80 2007 HDJ100 - DD |
#4 (permalink) |
yeah that carrier looks pretty munched. If you or a friend have a dial indicator set it up with the thimble against the carrier without the ring on it and spin it, runout should not exceed 3-5 thousands difference.
if i were you i would listen to wardamneagle and just look for a used diff, it will be much cheaper than rebuilding that one. If you do rebuild that one you will need to get bearings, shims, ring and pinion, and the carrier. usually the spiders and sides are pretty hard to break.
__________________
04 taco, 3.4 5spd. loads of goodies, loads of reinforcements, getting really hard to break. 85 pickup, 327sbc, truggy, in progress. 86 mazda b2000 street queen haha. 90 mazda mx-5 all orriginal. when in doubt, tach it out. |
#5 (permalink) |
Yes, it has a lift and 35 inch tires. What do you mean by the wrong size drive shaft? I'm guessing it's a factory drive shaft. It has 5:71 gears in it now. Well, at least in the front; the rear is empty.
We have the factory the original differential complete with the factory 4:10 gears. I'm thinking of getting a new 5:71 ring and pinion and a rebuild kit from 4wheelparts.com and swapping over all the 4:10 stuff to 5:71. The one that is broke has a locker in it, but it's messed up too I believe because we found a small spring in with the metal and crap that was cleaned out of the housing. |
#6 (permalink) |
I think the 5:71 is your problem. I thought they were described as being "weak". With 35's you should be running 5:29. Anyone care to correct me?
#7 (permalink) |
35's and 5:29's are perfect
and from what ive been hearing/seing is that 571's are weak.
__________________
91 Toyota stdrd cab short bed 22re 5spd. sas'ed, Yukon 5:29's. 3.5" tuff country e-z ride springs in the front. 5" allpro long travels in the rear. pro comp es 9000 shocks, 12" tg long spline front d shaft. k&n, 35x10.50x15 boggers. cobra cb/ashtray mod, 3' fire stick. etc. 2000 Toyota Tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flow master, etc. 2001 Toyota Camry, the girlfriends, www.22re.com |
#8 (permalink) |
Here is a good article discussing the strength of 5.71's:
http://www.gearinstalls.com/410suck.htm Also I am wondering, is that corrosion in there? You guys using a diff breather extension? Swamp water and/or mud getting drawn into the third through the stock diff breather could cause hell in any diff. That pinion looks mangled. The carrier does look a little beat. I'd take the 4.10 third you have and like you said rebuild it with 5.71's. That locker may be rebuildable too. Good luck to you.
__________________
1985 Extended Cab: 22re, 5spd, |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| replace rear diff. or entire rear end? | washington4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 02-24-2007 11:19 PM |
| 2nd gen diff question, v4 and v6 rear diff | taikowaza | 86-95 Trucks & 4Runners | 12 | 01-23-2007 05:25 AM |
| V6 4.56 Rear Diff | neoworm0 | Axles/Suspensions/Tires/Wheels | 0 | 12-02-2006 05:22 PM |
| replace rear diff or rear axle... in a bind | old 86 | 86-95 Trucks & 4Runners | 6 | 11-11-2006 10:20 AM |
| Will a 97 4x4 rear diff fit a 1997 2wd rear? | blown2wdtoy | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 09-22-2004 01:40 PM |
