Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Rearend shutter coming out of first gear?
so i fixed my driveshaft problem by drilling 4 new holes in the flange. but now, i cant remember if this was happening before i did that or if it just started because it could be my senses on high alert making sure nothing comes apart. But anyways when im releasing the clutch accelerating through first gear the rear of my truck is shuttering and i cant figure out what it is. Its not as bad or barely noticable if i take off real slow. my dad even drove it and noticed it cause i wanted to make sure i just wasnt driving the clutch weird. So can anybody help me out here?
__________________
1985 Extra Cab SR5, 5 Speed -5 inch lift -33x12.5 super swampers -snorkel -roll bar -Winch bumper -6 KC lights -bullet holes Last edited by rocklover : 08-11-2008 at 12:31 PM. |
| Sponsored Links |
#2 (permalink) |
does anybody know what this could be from?
__________________
1985 Extra Cab SR5, 5 Speed -5 inch lift -33x12.5 super swampers -snorkel -roll bar -Winch bumper -6 KC lights -bullet holes |
#3 (permalink) |
Did you happen to pull the rear shaft apart while working on it? If so, see:
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
thanks for that awesome link but i have a double cardan driveshaft, but im going to go see if the yokes are lined up anyways and see if that helps at all. Could there be anything else causing this?
__________________
#5 (permalink) |
OK, driveshaft type was not specified in the original post.
Might put the rear axle up on jack stands (block the front tires) and let the engine spin the tires and watch to see if there is any wobble anywhere. And see if the shaft meets the re-drilled flange flush.
__________________
#6 (permalink) | |
Quote:
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| my oil light is coming on when revved and out of first gear is my pump bad? | switchhoodrider | 86-95 Trucks & 4Runners | 6 | 10-23-2006 12:01 AM |
| '88 Rearend gear ratio question | WVpizzaguy | 84-85 Trucks & 4Runners | 2 | 10-07-2006 01:07 PM |
| Gear oil coming out the top of T-case? | steelhead | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 02-14-2005 07:18 AM |
| tranmission coming out of gear | SlimJim248@earthlink | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-18-2004 05:57 PM |
