YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-02-2008, 11:16 PM   #1 (permalink)
Question About Front Door Panels, Please Help!
Hey guys,
I have an 84 4runner that I need front door panels for. I found a nice pair that are from 84-89 but they are from a door which had power windows and a vent window (mine has neither...i have manual windows and no vent window). Would they still fit?? If not does anyone know a place where i could find some nice ones? I've looked on ebay and they're hard to come by in the salvage yards I live by. Any help is appreciated, Thanks!
RutRipper is offline
Sponsored Links
To remove this ad, register today!
Old 09-03-2008, 07:24 AM   #2 (permalink)
slacker's Avatar
yes ... they will fit .
you could actually gut the power doors , and remove the frame for the vent window(just a bolt in piece) , and replace with your manual stuff .. if you wanted .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5
MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 09-03-2008, 10:32 AM   #3 (permalink)
t0mwat3r's Avatar
wouldnt replacing the door be 110X easier?
t0mwat3r is offline
Old 09-03-2008, 12:06 PM   #4 (permalink)
Staff
aviator's Avatar
They should swap with no problems other then posibly having to cut a hole for the window crank.
Other then that you can make your own very easily with a little 1/8" hard board, some thin foam, fabric and spray adhesive.
Just use the old panel as a pattern and cut and/or drill out the holes to match.
It's actually quite easy.
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 09-03-2008, 05:56 PM   #5 (permalink)
slacker's Avatar
Quote:
HUH ?
maybe I didnt make myself clear . YES it will bolt on .
what I was saying .. is once you have replaced the door .. you can GUT it , and put the original door stuff in .. so they match . there is NO drilling or cutting ..
there is only 1 door shell from 84-88. they are interchangeable .
__________________
83 Trekker SR5
MY PAGE
NEW Trekker forum
slacker is offline
Old 09-03-2008, 11:46 PM   #6 (permalink)
That's what I was hoping...but i know there's a hole where the wires for the power window goes through the panel. If that isn't where the hole for the manual crank goes i would be effed cause I can't do fabricating work very well if i had to patch the hole and move it over a little. But the panel itself is the same size?? they're not longer for the models with vent windows?
Thanks for the help so far!
Old 09-04-2008, 12:21 AM   #7 (permalink)
Staff
aviator's Avatar
The panels are all the same for everything so far as lenght front to back goes. Base models only have a half panel top to bottom wise the bottom 1/3 was uncovered. On DLX models there was a full height vinyl covered panel and SR5 models had a full height vinyl but with the bottom 1/3 colour "matched" carpet. 1983 may have had a cloth on the SR5s.
84-88 models were the same except the SR5 had cloth for sure.
89-95 had full height vinyl on base and DLX models and cloth on SR5s.
Other differences included different armrests on different trim levels, door speakers 79-83 (depending on option pkg.) and so forth.
As for fabricating work don't worry the door skins are just about the easiest interior panel to fab. They are all flat. The armrests attach to the door itself not the skin as does the handle and everything else (except maybe the speaker box and map pockets).
__________________
tinted windows
aviator is offline
Old 09-04-2008, 06:40 PM   #8 (permalink)
slacker's Avatar
AHHHHH ... now I get it ..
your talking the INNER trim panels !!! sorry MY BAD ..
__________________
83 Trekker SR5
MY PAGE
NEW Trekker forum
slacker is offline
Old 09-06-2008, 03:36 PM   #9 (permalink)
"...there is only 1 door shell from 84-88. they are interchangeable..."
WRONG! The doors with wing windows are DIFFERENT from ones without. The frame for the wing window is welded to the door shell.
Re. the OP's questions: The rubber strip sealing against the window, and it's metal backing plate, are different for "vented" and "non-vented" interior panels. Although, you can use your old rubber strip and modify the backing plate without too much trouble. 'Don't know about the "holes".
anotherjeff is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
89-95 Toyota Interior (EVERY PIECE except front door panels) Okiyota Misc Stuff (Vehicle Related) 4 07-30-2008 10:31 PM
I need new door panels linuxrunner 86-95 Trucks & 4Runners 2 02-25-2008 07:25 AM
Door Panels Island_Yota General Vehicle Related Topics (Non Year Related) 6 12-26-2007 08:35 PM
Door Panels? wang 95.5-2004 Tacomas & 96-2002 4Runners 3 12-22-2004 06:07 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
