YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-18-2008, 09:09 PM   #1 (permalink)
staticx54621's Avatar
Pickup wont pass smog
i have a 1985 22r federal model. ive taken this truck to the smog station a few times and fail due to egr non funtional. all my exhaust tests are fine. so i was thinking if there is a different type of egr valve on the federal models. i know there is a negative back-pressure(which you have to plug the exhaust and then do the vac test.) ond the positive-pressure (where you just apply the vac.) Does anyone have experience with this same model. Thanks in advance for any help
staticx54621 is offline
Sponsored Links
To remove this ad, register today!
Old 08-19-2008, 04:22 PM   #2 (permalink)
anyone??????
Old 08-19-2008, 09:12 PM   #3 (permalink)
myyota's Avatar
Have you tryed removing the egr valve and clean it out ?, they can plug up with carbon and not work, also check all of the vacuum lines going to the egr and make sure there good. some trucks also have a vacuum modulator (i think thats what its called) that controls the vacuum going to the egr, if it goes bad the egr can either not get enough vacuum to operate or can get to much vacuum, depending on how it went bad.
myyota is offline
Old 08-19-2008, 11:20 PM   #4 (permalink)
On my 85 22re the EGR is attached to hoses/piping which lead to the thermo switchvalve. My piping was corroded and blocked so I replaced with hoses. You have to make sure the EGR valve, EGR Modulator, and thermovalve are plumbed correctly. Ask the mechanic if the EGR failed because there was no vacuum at the EGR Valve or if the EGR valve is stuck open.
pcmentor is offline
Old 08-20-2008, 12:07 AM   #5 (permalink)
i put a new egr valve on there after my first smog test. and all the hoses are routed correctly. but i havent tested the thermo valve yet. ill do that today. but what i am still wondering is if the federal model is a negative back-pressure egr valve.
Old 08-20-2008, 10:20 AM   #6 (permalink)
Pages EC 30-33 of the FSM (available here http://www.ncttora.com/fsm/1985/1985FSM.pdf )gives the testing procedure for the EGR, and the vacuum routing so you can answer your question. It is fairly common for the plumbing to become totally packed with carbon. Might be worth your time to remove the piping and clean it.
landozion is offline
Old 08-20-2008, 09:13 PM   #7 (permalink)
Does anyone else have egr vacuum metal piping clogged with gunk/rust? The four little metal piping welded together. Is the problem that the vauum isn't getting to the EGR valve?
pcmentor is offline
Old 08-22-2008, 07:50 PM   #8 (permalink)
yotaman_79's Avatar
Send a message via Yahoo to yotaman_79
i do have that 4 little metal pices i would like to take them off but i dont know how it will harm the motor. i would like to have a clean looking motor
dont know if i should do it or not could use some help too
yotaman_79 is offline
Old 08-23-2008, 06:07 PM   #9 (permalink)
Blow air through them to see if they are clogged. If so replace with rubber hose.
pcmentor is offline
Old 09-01-2008, 07:40 PM   #10 (permalink)
littlecommando's Avatar
I thought that 1985 was old enough to not have to pass test
__________________
1985 Toyota 4Runner SR5 4WD red, mostly stock, mossy oak seat covers, custom stereo system, Dixie Horn, Custom Rear Bumper
Build Up
Powder Springs, Georgia
littlecommando is online now
Old 09-01-2008, 07:58 PM   #11 (permalink)
In CA it's 1975 and older.
pcmentor is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
exhaust running to lean. wont pass smog weakyota91 86-95 Trucks & 4Runners 14 05-17-2007 12:36 PM
Think this cam would pass smog? JEDI87 86-95 Trucks & 4Runners 4 04-26-2007 09:18 AM
cant pass smog 3.Slow jandk2005 86-95 Trucks & 4Runners 38 05-21-2006 11:31 AM
help me pass CA smog test please 2wd1stgen 95.5-2004 Tacomas & 96-2002 4Runners 9 06-05-2004 07:43 PM
Please help pass CA smog test crznL98 95.5-2004 Tacomas & 96-2002 4Runners 3 12-18-2003 11:23 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
