| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Parasitic battery drain head ache!!!
#2 (permalink) |
How fast does it drain down, like overnight or over a few days! that .474amps right? And are you checking it after the truck sits for about 10 minutes while keeping the cable connected to the battery and the ammeter. You know dont disconnect the battery then put the ammeter on it, disconnect it while the ammeter is connected.
__________________
-Colton- 1989 Toyota Pickup DLX, 22RE, 5-spd, 5-in SAS, Detroit back, ARB front, longs, 37/13R15 Boggers, Marlin front and rear bumpers, Marlin sliders, Ramsey Patriot 9500 winch with synthetic line, Hi-angle D/S F&R, diff breathers, rebuilt tranny, 22RE bored .20 over completely rebuilt (it feels great to not have to buy 2 cases of oil a month!!), whole truck built in memory of my dad (RIP 6-26-08) Daily driver & tow vehicle: 02 Dodge 2500 Diesel, 5-speed, 4wd, quad cab, longbed, 128k miles |
#3 (permalink) |
Drains down overnight and sometimes even less. Checked it about 15 mins after the truck was cut off. Didn't know i had to connect the ammeter before a took the cable loose. Thanks, i'll try that. Still anyone know about those wires?
#4 (permalink) | |
Quote:
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) |
large plain white wire is probably the alternator B+ (main) wire. If it is, then remove the alternator for testing. Er, what 4crawler said.
To connect the ammeter to the car, wait 2 minutes before unplugging stuff because the car's systems will draw more current when the battery is hooked up. Once everything settles down, do your tests.
__________________
- Brian 84 toy pickup mostly stock |
#6 (permalink) |
I had a similar prob , ina diff type car for about 3 years; couldn't figure it out, but if I didn't start the car at least a couple of times a week, car would die.
finally took it to my mech's to figure it out; one morning, while still dark, they had worked on if for a few days allready and could not figure it out- one early morning one of his mechs' walks in, my car is inside the garage, and it is very dark in there still. He walks over to the car, and notices, " something looks like it is on in there!" He turns off every available light in the garage and office, and looks back in the car. Opens the passenger door, looks inside the glove compartment; The glove compartment light is on!!!! how sick is that??? He disconnects the light bulb- problem solved! Switch on door of glove compartment had gone bad... |
#7 (permalink) | |
Quote:
gNARLS. |
#8 (permalink) |
Staff
Having a similar problem if i drive in the wet and don't start again for a few days...
Batt. shop thinks it might be shorting through the damp on top of the batt. But i'm going to try the alt cable too... these wires are getting old now...
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
| Tags |
| battery, cost, diesel, dodge, drain, night, parasitic, techparasitic, yota, yotatech |
