| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
other body parts that fit
#2 (permalink) |
You might consider replacing the front and rear wheel bearings, if there bad they can cause a vibration. The transfer case is seperate from the trans, there is a drain plug and a fill plug on the fransfer case.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#3 (permalink) |
The cab swap really isn't that hard just a little time consuming. And as for the beds I'm not so sure if the mounts line up but if they don't you can cut them off and weld them where ever they need to be.
