Optimal RPM range - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-23-2009, 05:09 AM   #1 (permalink)
kcpanages's Avatar
Optimal RPM range
What is the best rpm to stay at while playing in mud? what does a 22r red line at? i would like to set my shift light so i can know when im getting to the best rpm with out slinging my motor apart. i try to stay around 4500.but feel i can bring the rpm's up a lil more. not sure.... im running 5.29 gears and 38.5 boggers.
kcpanages is offline
Old 04-23-2009, 11:18 PM   #2 (permalink)
kcpanages's Avatar
any help?
Old 05-20-2009, 09:22 PM   #3 (permalink)
yotahead87's Avatar
i think i saw on my buddies sr5 the redline on a 4 cyl is almost 6k. not positive though. run it till you hear the valves float!
yotahead87 is offline
Old 05-20-2009, 09:29 PM   #4 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
22RE will run at 5-6K all day long.. ask me how I know
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Old 05-20-2009, 09:31 PM   #5 (permalink)
toyota4x4907's Avatar
Send a message via MSN to toyota4x4907
redline is 5750.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 |two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler
'88 4runner|22re|5spd|206K miles|Sold
'93 single cab|22re|5spd|150K miles|Sold|
Pro IFS
toyota4x4907 is offline
Old 05-20-2009, 09:32 PM   #6 (permalink)
Kiroshu's Avatar
22rs red like runs about 5500-6000RPMS.... i dont wanna burst ur bubble but its not wise to push the 22r that hard all the time... wears a motor quicker with high rpms.... i mean unless it beefed up and or low miles or new you kinda should not do that with the 22r or really any motor... you will see thats how they start knocking.... 22rs dont like high RPMS....the 22r produces all its HP at 3800RPMS anyway you don't need red line.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 05-20-2009, 09:39 PM   #7 (permalink)
Quote:
22r= ~96 hp @ 4800 rpm, ~ 129ft/lbs @ 2800
22re= ~116 hp @ 4800 rpm, ~142ft/lbs @ 2800 rpm
__________________
Pro IFS
Old 05-20-2009, 09:42 PM   #8 (permalink)
Kiroshu's Avatar
well 4800 lol forgot a 1000 but still.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
Kiroshu is offline
Old 05-27-2009, 07:54 PM   #9 (permalink)
kcpanages's Avatar
thanks guys. i set my tach for 4000 rpm for shift light. in 3rd and 4th gear in 2H its hard to bring the rpms up fast with 38.5 boggers. but tachs up pretty good in 4L......
__________________
1985 YOTA PICKUP
HAD 22RE SWAPPED FOR 22R
WEBER CARB
MSD IGNITION
7" SPRINGS
2" SHACKLES
3" BODY
5.29 GEARS
SPOOL FRONT AND REAR
15/38.5X16 BOGGERS
ALL MECHANICAL GAUGES
PLUS ROLL BAR AND LIGHTS
Tags
22r, 22re, 4runner, acceptable, changing, gears, high, manual, optimal, range, ranges, redline, rpm, rpms, shifts, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Optimal jack/stands for suspension work rds0811 03+ 4Runner/GX470, & 05+ Tacomas 8 02-11-2009 04:53 PM
Snowboarding - Which Wax & Technique is Most Optimal? Rock Slide Off Topic Talk 16 01-03-2008 09:37 PM
How to clean a motor and things to consider for an optimal tune up! semo 95.5-2004 Tacomas & 96-2002 4Runners 8 12-20-2007 08:02 PM
Range of Wireless SLC Punk Computer Talk 23 01-27-2005 11:42 PM
305/70/R16's What's the optimal back spacing? TStango 95.5-2004 Tacomas & 96-2002 4Runners 3 07-19-2004 08:01 AM
2009 InternetBrands, Inc.
