Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
My rig is leaking oil what looks to be near the water pump pulley.
![]() I've got an 84 22R. MY autozone guy tells me it may be the oil pump throwing oil because the relief valve is failing. He tells me I should replace the oil pump. MY oil pressure gauge reads from the lowest mark when idling and at the first mark when hitting around 2-3k rpm's. Also my valve cover breather tube that connects to my air cleaner is leaking some oil when running higher rpm and when it gets hot, it blow a little white smoke. My engine is just under the 50k mark from a rebuild. I am running Valvoline 15W40. Any help would be appreciated!!
__________________
84 Yota 4x4 22R 9" Lift 35" mudders 3" SMOKE STACK "REDNECK RIG" Last edited by 84YotaBigRig : 08-03-2008 at 09:51 PM. |
| Sponsored Links |
#2 (permalink) |
#3 (permalink) |
Timing cover, oil pump o-ring, valve cover & half moon seal, and front crankshaft are the main areas of leaks for the front of the engine. You gotta thoroughly clean the front of the engine to pinpoint exactly where the leak is coming from.
As far as oil pressure, the gauge isn't exactly accurate, so I wouldn't take its reading seriously. Many people will rebuild their engine and fail to replace the oil pressure sending unit. The oil pressure sending unit has an internal rubber diaphragm inside that gets weak over time and starts giving lower, false readings. Buy an external oil pressure gauge and take a reading at cold idle, hot idle, and 3K RPM with a hot engine to determine what your oil pressure truly is. As far as oil blow-by, this could be bad valve seals or rings. The engine shouldn't be having blow-by issues with that mileage and 15-40 oil. I have a feeling you were taken advantage on a poorly rebuilt engine. That's why I ALWAYS do it myself and even check the work of the machine shop using bore gauges and micrometers. |
#4 (permalink) |
Because it has the proper amount of zinc and other lubricating qualities that "normal" oil no longer has. Also, Toyota recommended 20-50 oil until 84 where emission tightened up further. These are "loose" engines which require thicker oil. 15-40 is the best oil you can possibly run in the 22r series engine.
#5 (permalink) |
I've got a '84 too and I thought the manual called for 5w30. I could be wrong. I've had mine for a little over year and use Mobil 1 5w30 and no issues. 130K original miles on the motor/truck.
__________________
84 4runner, 6" suspension lift, 35" BFG's, 5spd 03 Tacoma Dbl Cab, TRD Off-Road Package w/ E-Locker, Revo's |
#6 (permalink) | |
Quote:
Some people just have no idea how oil/engines work. Even if the xxw-50 or xxw-50 was correct (and I highly doubt the latter) the lower number should always be no higher than 5w these days. The only way to really tell what a particular engine "needs" requires an oil temperature and oil pressure gauge. ![]() Fred |
#7 (permalink) |
Had a similar leak a few months back. Found part of the timing chain cover gasket was ripped and pushed out from between the block and cover, took a weekend to replace without removing the head and havn't had any problems since.
__________________
84 Extended cab |
#8 (permalink) |
I run 10W40 in my 84 22r. But then I live in st. george, utah, and we were over 105 all last week.
__________________
Trail Truck: 84 regular cab 85 22r -- streetRV head, 261C cam, 2.5" flowmaster, lock-right in rear, 1" Wabfab BL, IFS brakes, rock sliders, diff breathers, Amsoil, dual cases, front rock lights, tube bumper, 33x12.50 BFG MTs, 213k miles ---Currently: 5.29 prescion gears, cryo'd (just need to get them installed) send money ---Next: Front bumper Link to build-up: http://www.yotatech.com/f115/jmazoso...uildup-137611/ DD: 01 Tundra V8, 3" flowmaster, FIPK, 120K miles |
#9 (permalink) |
It looks as though the front and rear seals to the oil pump were shot. Autozones computer was the one that suggested 15W40. By the way jmazoso, I am from St. George but I moved to Tacoma, WA. Sure miss the heat and especially the sun!!
__________________
84 Yota 4x4 22R 9" Lift 35" mudders 3" SMOKE STACK "REDNECK RIG" |
#10 (permalink) |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 93 Pickup Lagging/Slipping/Oil Problems??? | wancosc356 | 86-95 Trucks & 4Runners | 5 | 07-07-2008 09:31 PM |
| Oil problems! | cztheman64 | 86-95 Trucks & 4Runners | 3 | 05-27-2008 09:59 PM |
| 22RE valve train oil problems | InternetRoadkill | 86-95 Trucks & 4Runners | 0 | 10-07-2006 02:10 PM |
| 22RE Oil Filter Problems | kryptik | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 07-26-2005 04:47 AM |
| 02 tacoma oil filter removal problems | farmred | Maintenance & Repair Archives | 6 | 07-03-2003 02:57 PM |
