Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Oil Pressure problem
Ive searched this forum but still cant find my problem.
I just rebuilt the engine with a new master rebuild kit whick included a new oil pump. When I first start the engine (either hot or cold) I dont show any oil pressure and get alot of engine noise until the oil pressure comes up. It could take up to a minute of higher RPMs to see pressure but most often oil pressure comes up in about 15 - 30 seconds. It almost sounds like the oil is draining from the system and loosing prime when the engine it turned off. Surely others have had this problem. Any help is appreciated.. Im nervous about starting an engine with no oil pressure
__________________
85 4runner...22re engine |
| Sponsored Links |
#2 (permalink) |
Do you have an oil filter with an anti-drainback valve?
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
try putting a toyota brand oil filter in, then see what happens.
__________________
- Brian |
#4 (permalink) |
check your timing cover /top oil pump bolt !! (this is a pic of the back side)
if it is the wrong one , it could contact the tensioner , and hinder it's performance , and reduce oil pressure . WRONG BOLT will go threw the cover ![]() correct bolt , will NOT go threw the cover ![]() .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 MY PAGE 2WD fourm I frequent NEW Trekker forum |
#5 (permalink) | |
Quote:
__________________
Redneck trapped in a brown man's body |
#6 (permalink) | |
Quote:
#7 (permalink) |
thanks for everyone help..The oil filter is one from an autoparts store or walmart...cant remember now where I got it.. Ill replace it and see if that helps.. Ill aslo check the oil pump bolt too...
Any other suggestions???
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oil Pressure Problem | nolimit | 86-95 Trucks & 4Runners | 9 | 08-28-2008 08:07 AM |
| NEED HELP! - Low oil pressure & leaky oil breather | boosted86 | 86-95 Trucks & 4Runners | 4 | 08-12-2008 09:10 PM |
| oil pressure problem | elmer fudd | 86-95 Trucks & 4Runners | 25 | 10-15-2007 08:39 PM |
| oil pressure problem? | norcalsvx | 86-95 Trucks & 4Runners | 10 | 10-14-2007 06:29 PM |
| Best location for new oil sender (Autometer oil pressure gauge) | Bob_98SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 10-20-2004 03:13 PM |
