| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Oil out around the distributor shaft?
__________________
84 Extended cab |
#2 (permalink) |
There is an o ring on the distributor that can go bad and cause an oil leak, you have to remove the complete distributor to change the o ring.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, Trail Gear High Steer, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, AFM Upgrade, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#3 (permalink) |
yeah, already have it out, my o-ring is just so hard it feels more like a nylon ring. Did some Bing'n, I think I'll just pick up a new o-ring and saw off the old one
Only $3.50 for a new one and appears to be a somewhat common spot for a leak.
__________________
84 Extended cab |
#4 (permalink) |
The o rings become hard from the engine heat over the years and start to leak.
__________________
| Tags |
| bad, change, distributer, distributor, gasket, leak, leaking, oil, oring, orings, shaft |
