new third member
new third member
I am buying a complete kit 5.29 gears and ARB locker, but i was wondering since i am switching the 3rd member out can i switch to running a HP in my 4cyl 8" housing?
my tuck
currently I have an 85 Toyota pickup 4cyl. i have a 3" lift installed but a 4" at thwe house waiting to go in. I just ordered the low pinion 3rd member for the front, but got to thinking if i could hae oredered thr high pinion for the 4cyl *' straight axle housing
I just find it weird that the HP would bolt right into the 4cyl 8" housing no issues, and the complete HP thrid isnt cheap so i just want to make sure there isnt any issues or instructions that i am missin. I have been searching for answer but always seems to never be straight forward.
It will bolt right in, with 5.29's you may have to rotate the ring gear slightly when you install it
I believe the high pinion requires a different gear set than standard thirds.
Are you having someone set up the gears for you?
Setting up gears is kind of an art from IMO, especially when throw an ARB and routing the inner copper tube..
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
