Sign in using an external account
| 84-85 Trucks & 4Runners 2nd gen pickups and 1st gen 4Runners with solid front axles |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Need part number for Clevite 77 Main and Rod Bearings
#2 (permalink) | |
Personal
Sales Rating: (0)
Quote:
main bearings= TW-463S rod bearings= CB-1218P Piston rings. NPR reference number is SWT-10103. And as far as I know piston rings have to be ordered after you determine the exact piston width. But dont quote me. Im not a pro. Rod and main bearing set on e-bay= http://www.ebay.com/itm/Rod-Main-Bea...-/290420995620 Best I could find on google for you.
__________________
85 in the works |
#3 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
TW-463S is for thrust bearings though? Last edited by LT1UltraZ; 01-23-2013 at 01:48 AM. |
#4 (permalink) |
Personal
Sales Rating: (0)
Took me less than 2 minutes to find the part numbers on MAHLEClevite.com.
CB-1218P is for standard size connecting rod bearings ![]() MS-1590P is for standard size main bearings ![]() TW-463S is for standard size thrust washers(bearings)
__________________
We're sorry, theYOTATECH member you have reached is temporarily out of order or is no longer in service. Please feel free to ask our many other highly informed members about your problem. Or try using the search feature to find the appropriate information by yourself, and solve the issue on your own. Thank you for choosingYOTATECH. Good bye. I'm Cuckoo For YOTA Trucks! |
#5 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Thanks Mudhippy i got 1 more question for you if you dont mind, which rings would you recommend? pistons are stock, so is the block, it just going to be a quick hone with a drill bit as stock crosshatch is still on there. I was planning on going with Total seal gapless but i would love to hear your opinion. I also noticed in one of your post you have said not to even bother checking the ring gap, i was hoping you could expend on that a little. Thanks! |
#6 (permalink) |
Personal
Sales Rating: (0)
NPR
Checking ring gap is just unnecessary in most cases(especially stock). If the bores/cylinders have been sized correctly, then the rings that are the corresponding size will already be correctly gapped(within factory specifications) right out of the box. This is because piston rings are manufactured under extremely tight tolerances to be exactly the size they're supposed to be. And because piston ring gap specs are fairly standardized in the industry(nearly the same for all makes).
__________________
#7 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
ACL / KING/ Clevite 77 ? Thanks |
| Tags |
| 22re, 22rec, 77, bearing, bearings, clevite, connecting, identification, number, numbers, reference, rod, size, sizes, standard, toyota |
