YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-05-2008, 10:40 PM   #1 (permalink)
My '85 Build...In Progress (pics)
First off this is my third 4runner, I had an 88, and 95...
Finally bought this about a month and a half ago...
Overpaid some might say, I love this body style, so to me it was worth it...
Little back ground on it, The seller was geting deployed to Japan had no place to store it. Seen it in action on the trail in our club... So I Sold my 95 plunked down 4500 dollars and bought it...
As purchased,
4cyl, 5-spd, 5.29 gears, v6 rear axles, 3" rancho springs front, steel brake lines, 35" pro comp tires on 16"x10" WELD RIMS. After-market Shackles front and rear, Rear Lift blocks on stock leafs..(this is the reason I started the re-work and it just kept on going...) All-Pro front bumper, rocksliders, Rear Tube Bumper, Extra set of 35" tires on 15"x8" amercain racing rims. Cobra CB and spooled front... Welded Spooled Rear. Centerforce stage 2 clutch..Lame looking cut fenders he put on..Spooled Front Diff(that is a brutal setup with push pull steering..)
Here is a pic from last October at truckhaven, and one from 2 weeks ago
2 weeks ago
Made a list of things I wanted to do with it, These are the fixes and mods doing right now..
4 point harnesses in rear for kids..DONE
Oil pump, full tune up, front crank seal, Headers from LCE..DONE
57" rear leafs, Detriot Locker....
Custom built rears to fit front, Spring hanger, 47" long Springs
Custom Shock Hoops
U-bolt flip kit front and rear
Hy-Steer
Wheel spacers
custom drive shaft
Kill Switch
All Work(execpt harnesses) done at Jacks Fab in El Cajon, CA
My Goal was to make a capable rig now.. Think this well be a nice start
Opinions and suggestions welcome...
imabig is offline
Sponsored Links
To remove this ad, register today!
Old 09-06-2008, 01:10 AM   #2 (permalink)
Jeenyus04's Avatar
get rid of the fenders! lol and maybe put a real locker up front. Good looking rig tho!
__________________
85 reg cab s/b, rebuilt 22r, .040 over bore, engnbldr's crawler cam, no cat w/ flo-pro (was on it). tg 5 inch lift. 35 baja claws bright green paint, sliders, custom front bumper, miller rear locker --project--
02 dodge extended cab s/b, black sport, 24 vavle cummins, 35's, 4 inch exhaust, edge ez
Jeenyus04 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rig Build Progress and 35's hross14 95.5-2004 Tacomas & 96-2002 4Runners 24 03-19-2008 08:30 PM
UNBREAKABLE FAB strikes again! TACOMA build, STILL IN PROGRESS codyjh 95.5-2004 Tacomas & 96-2002 4Runners 5 09-30-2007 06:48 AM
3.0 with 3.4 power? Build up in progress - donations needed!! Cebby 95.5-2004 Tacomas & 96-2002 4Runners 164 06-11-2006 07:34 PM
Front Bumper build progress obex26 The Fab Shop 14 08-25-2005 07:28 AM
3VZ build progress......with pics knaffie 95.5-2004 Tacomas & 96-2002 4Runners 10 05-23-2005 01:34 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
