Low compression on Rebuild - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-07-2009, 07:02 AM   #1 (permalink)
toyotabull's Avatar
I rebuilt a 1984 22R shortblock 3 weeks ago before I came back to work, and I went back with the same head, a stock 20R. Now I cranked it up before I came to work and it sounded great and ran very good, and had a compression test done on the cylinders a few days after I got to the rig and the readings are all around 110 PSI. standard size pistons, I know its a tall deck 22R block , but why the low compression readings
110 105 115 110 Thanks
__________________
85 toyota rancho lift
33 in tires on 15X8 steel
270 lift cam and flat tops
Those who do not learn from history are doomed to repeat it, or they're showing up their friends. Again!
toyotabull is offline
Old 11-08-2009, 11:42 AM   #2 (permalink)
toyotabull's Avatar
After alot of hard thinking and playing 20?'s with my brother, I have figured out why it runs good but has low compression. Now there are 2 types of compression testers. #1 is the bolt in unit, dont have to worry about it leaking and getting a wrong reading, and then there is the one my brother used. The push in, yeah, the one with the rubber nipple that you press firmly into the spark plug hole. So I figured it out and he is not allowed to work on yotas again, and ill post the right readings when I get home Wednesday.
__________________
Old 11-08-2009, 06:05 PM   #3 (permalink)
harbor_bomber350's Avatar
you might have your rings backwards on the pistons
harbor_bomber350 is offline
Old 11-09-2009, 10:33 AM   #4 (permalink)
toyotabull's Avatar
I hate to pull it down and check, but if I do then I'm putting a bigger set of pistons in there and sending everything back to the machine shop just in case. I'm out here on the drill ship right now catching about 20-30 foot waves from Ida, this thing is rocking.
__________________
Old 11-09-2009, 10:49 AM   #5 (permalink)
ya my freind just rebuilt an engine and that was his problem but ive also heard that if you put some money into the rebuild you can get the 22r to push 200hp .
ya i wouldnt want to be out there right now, i hope your rakin in the money for being there
Old 11-09-2009, 12:42 PM   #6 (permalink)
toyotabull's Avatar
Yeah, its not too bad out here, worst we have had is about a 30 foot wave but its slowing down. Back to the engine, all the rings were in marked packs from engnbldr, and unless they were packaged wrong (which i dont see happening) then Im gonna have to look into the cam setting, might be a tooth off. Ill let ya know when I get home wed. And the drill ship is 835 feet long by 125 feet wide, so its hard to rockit, but when it does!!
__________________
Old 11-19-2009, 02:48 PM   #7 (permalink)
toyotabull's Avatar
So I got home last week and ran another compression check, and guess what, 110 115 110 110, put a little oil in each cylinder and ran a leak test, and the test came back good with minimal ring leakage, and still avg. of 110 psi on each cylinder. HELP?
__________________
Old 11-19-2009, 03:55 PM   #8 (permalink)
Kiroshu's Avatar
Do you have a screw in compression tester? Where did you buy the gauge and is it reading right? If the rings were in backwards there would be more leakage than that it be like about 60-80% leakage. Check you valve clearnances. Do the pistons come all the way up to the TDC postion? timing....
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Tags
31, compression, good, low, rebuild, runs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
