Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Leaking clutch fluid
I've been needing to refill my clutch fluid almost daily. I think I need to replace my Clutch Master Cylinder. Could it be anything else? I haven't had the time to isolate the leak, but any hints on where to look would be a great help.
__________________
84 4Runner. Weber 38 carb, LCE Weber Carb Riser, LCE 2.25 Header, Magnaflow Cat, and Muffler. Stock wheels, and suspension gotta go next |
| Sponsored Links |
#2 (permalink) |
Look under the dash were the shaft comes out of the clutch master cylinder, if you can see or feel fluid comming out of the master cylinder its bad. I had to replace mine last week because it was leaking. also check the slave cylinder that operates the clutch, they can also leak .
#3 (permalink) |
Sponsoring Member
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab FOR SALE: 1987 4Runner GRAY FOR SALE: 1987 4Runner RED 6th Annual South East 4Runner Jamboree, May 22-25, 2009 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Leaking Powersteering fluid | darkglass | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 05-05-2007 12:36 PM |
| 04 4runner leaking transmission fluid | mich34 | 03+ 4Runner/GX470, & 05+ Tacomas | 1 | 11-05-2006 11:21 AM |
| Clutch leak/Dark clutch fluid | geoduke | 86-95 Trucks & 4Runners | 2 | 04-04-2006 07:51 PM |
| Leaking Tranny fluid! | kenandjenn | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-25-2005 04:52 AM |
| Fluid leaking from | Jesters_taco | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-08-2004 06:32 PM |
