YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-07-2008, 11:22 PM   #1 (permalink)
84YotaBigRig's Avatar
Question Knuckle seal replacement...
MY knuckles are just out oil all over my brakes especially the drivers side! How hard is it to replace the seals on those suckers? Any links on a how to would be great!
__________________
84 Yota 4x4 22R 9" Lift 35" mudders 3" SMOKE STACK "REDNECK RIG"
84YotaBigRig is offline
Sponsored Links
To remove this ad, register today!
Old 08-08-2008, 05:22 AM   #2 (permalink)
WFO
WFO's Avatar
Its pretty simple. Heres a write-up on rebuilding the axle. You obviously wont need to rebuild everything.
http://www.birfield.com/~morgan/tech/axle/
Check out Marlin for the kit. You should go ahead and replace the Trunion bearing while you have them out. Plus you can just buy the kit that has everything you need.
Oh and this will probably come in handy: (Taken from Pirate FAQ)
Cone Washers
Cone Washers for Aisin or Asco Locking Hubs - 42323-60010
Cone washers for solid axle steering arms - 42323-60020
Cone washers are the washers that are behind the nuts holding on Toyota wheel hubs and steering arms.
Cone washers are a pain in the a$$. Anyone from the dry areas of the southwest will tell you that a good smack on the stud will loosen them up. If you are in or near the Midwest... forget that.
Using one or all of the following (most likely all) you should be able to get them off.
· Soak it in something like PB Blaster
· Put the nut on the stud and hit the nut with a brass drift and hammer
· Use an air chisel - being careful of studs etc
· Wedge a screwdriver or similar into the small slit of the washer
· Beat the hub housing like a red-headed step child with a hard plastic or rubber mallet. If worst comes to worst (and if you are in the Midwest it probably will) then you can try hitting the hub housing itself with a small sledge hammer. At this point you will want to hit it with one anyway. The trick is not hitting hard enough to damage it.
I (toy4crawlin) have heard to apply "Anti Seize" to cone washers to prevent them from sticking.
WFO is offline
Old 08-08-2008, 05:49 AM   #3 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
You need to just get a knuckle service kit. Check the FAQ on Pirate for tons of info or try a simple of something like "Toyota knuckle rebuild". No sense in tearing the whole knuckle apart without doing some preventative maintenance while you are in there just to replace the axle seals.
waskillywabbit is offline
Old 08-08-2008, 08:48 AM   #4 (permalink)
Thanks for the info!
__________________
Old 08-13-2008, 09:53 AM   #5 (permalink)
I would highly recommend Marlin's new inner axle seals.
http://board.marlincrawler.com/index.php?topic=32224.0
Since installing them I have had dry knuckles, even after hard wheeling outings. They are a bit costly, but highly worth it!
__________________
1985 pickup w/ duals, cage and armor
2003 tacoma 4x4
halfxspaid is offline
Old 08-13-2008, 10:01 AM   #6 (permalink)
dirtoyboy's Avatar
If you are doing a complete knuckle rebuild I would recommend using Toyota parts only...especially the bearings (should be NSK and Koyo brand) except for the axle seals....check out marlins seals..they are beef! (I never knew a seal could be beefy until I was one)
You can use them more than once (usually) and they work great
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 08-13-2008, 10:43 AM   #7 (permalink)
Sponsoring Member
Old 08-13-2008, 11:17 AM   #8 (permalink)
dirtoyboy's Avatar
Quote:
Originally Posted by waskillywabbit View Post
Forgot to take my dyslexia meds today....that should be SAW not WAS....lol
oh man i need a drink right about now
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Knuckle arm replacement? Phantez 84-85 Trucks & 4Runners 10 01-17-2008 07:02 PM
Crankshaft seal replacement on a 3.0 Charger92 86-95 Trucks & 4Runners 3 10-22-2006 12:08 PM
89 Rear main seal replacement bryanr 86-95 Trucks & 4Runners 6 12-23-2005 12:52 PM
need help steering knuckle seal????? chasmc2 95.5-2004 Tacomas & 96-2002 4Runners 7 05-18-2004 12:14 AM
main seal replacement nelly781 95.5-2004 Tacomas & 96-2002 4Runners 8 12-05-2003 03:22 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
