Instrument cluster/alternator
I removed and replaced my instrument cluster with a sheetmetal assembly I made with some autometer guages. Is there a circuit in the cluster that is open that is tied into the charging system? Now my alternator won't charge. Any ideas or suggestions will be appreciated.
I can post pics later, for now it is a 85 22r. I used polised aluminum diamond plate with 4 autometer gauges: tach, volt, water temp, and oil pressure. I wired them all individually per the autometer install instructions, so the factory wires are just stuffed back in unconnected to anything. I took a quick look at the scematic and it looked like if I connected the black/yellow and yellow/white wires that the circuit would be complete. Tried it with no luck.
wiring diagrams can be found here:
http://ncttora.com/fsm/index.html
first link is the one you want
welcome to YT!! upload your pics to a free hosting service like photobucket.com
Yep, offroad mostly. I live about 6 miles from the trails that my friends and I ride. All rural roads, so as long as I drive in the middle of the group on the way there my speed will be judged off of them and no inspections around here.
greasyglue
12-12-2015 12:57 PM
rushw
07-18-2015 01:46 PM
