YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-07-2008, 02:18 PM   #1 (permalink)
forwardtocharis's Avatar
Idle Speed?
According to my tach my truck's idling at just a hair under 500...
It's a little rough, but it manages just fine, I'm just a little concerned because the idle is so low that it could cause a problem somewhere?
I have 2.5" pipes, short air intake w/ cone filter & an electric fan...
__________________
'85 4Runner DD
Anti-sway mod/Diff Breathers/XRC 8000 Winch/Smittybilt Front Bumper/Custom intake/2.5" exhaust/Custom Stereo
forwardtocharis is offline
Sponsored Links
To remove this ad, register today!
Old 08-08-2008, 07:38 AM   #2 (permalink)
My 85 22re is supposed to idle at 750 and it does. Using a tester.
Also a while back my battery was failing but all I notcied is the idle was too low(before I had a tester) and my electric compass would shut off due to power drop at low idle. Low Charging and having it die like when you put it gear(auto) and low oil pressure are the only downside of low idle I can think of.
My dash tach says 500 when the actual idle is 750.
pcmentor is offline
Old 08-08-2008, 08:24 AM   #3 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Is this a 22r or RE? Is the poor idle related to temperature? And, how's it running otherwise?
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 08-08-2008, 11:16 AM   #4 (permalink)
Thanks pcmentor, i'll look into another tester
it's a 22re, runs cool, no problems whatsoever
__________________
'85 4Runner DD
Old 08-29-2008, 05:44 AM   #5 (permalink)
I got a Sunpro Model CP-7678 meter that has low/hi tach function, also duty cycle for injectors. I found a used one at auction for $5 plus $8 ship. You can get a brand new one for $35. I also just bought an Actron timing light with RPM for $70 free ship at Amazon.
pcmentor is offline
Old 08-29-2008, 06:11 PM   #6 (permalink)
abecedarian's Avatar
If the idle is too low a few things will be negatively affected:
oil pressure
connecting rod bearings and wristpins
timing.
__________________
Quote:
Originally Posted by me
If you don't know why people are laughing at you, maybe you don't know yourself as well as you thought you did... or maybe they voted for Obama.
abecedarian is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Idle Speed jutoledo Newbie Tech Section 2 12-07-2007 01:46 AM
Idle speed ?'s BAZ 86-95 Trucks & 4Runners 2 12-28-2005 11:20 AM
3.4 Idle Speed benzim 95.5-2004 Tacomas & 96-2002 4Runners 2 10-20-2004 09:01 AM
Idle speed Paul H. 95.5-2004 Tacomas & 96-2002 4Runners 4 08-11-2002 11:33 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
