Hub Reassembly Advice
85 Toyota Truck - 22RE
I'm in the process of reassembling my hubs after tearing down to change the rotors. As it was necessary to remove the outer bearings(meaning I need to repack them) it seems wise to go ahead and remove the rear seal, remove the inner bearings, clean out all of the grease in the hub, repack both sets of bearings, re-grease the hub body and replace the rear seal(available from NAPA) while I'm at it. My book(Haynes) describes a procedure for applying grease inside the hub after it has been all cleaned out that involves putting a small amount of grease behind each race and forming a damn with your finger behind each race.
This seems fine but will not result in anything like what I'm seeing in the hub currently. There is a big band of relatively clean grease around the entire circumference of the hub body that is probably 3/4" or so deep(based on a little poking with a screwdriver)
Is the book procedure accurate or should I end up with something like I already have? Did somebody previous just do some serious overkill? The band of grease is so evenly applied that it makes me think it was factory, but then again maybe it was just piled in there and centrifugal force spread it out. I've also never packed bearings. Is the book procedure in the picture good or should I know more / do it differently?
It also seems like it would be a good idea to replace the gasket between the hub body and the manual locking hub but I haven't been able to find this part at any of the auto parts stores. It looks OK but is a little bunged up from a couple of poorly aimed stud-removal blows.
Should I concern myself with this gasket at all?
I've done quite a bit of research and watched/read everything I can find but these issues don't really seem to get addressed in any detail. Any help or advice would be much appreciated. Is there anything special I should do when putting the manual locking hub back on in terms of grease or maintenance?
Thanks in advance for any help or advice. If I've placed this post in the wrong location I'd be happy to delete and move and I'm sorry for any inconvenience.
Full Album
Full Album
I do like my hand Condoms for packing bearings
Pretty much like your article stated put the correct grease in the palm of your hand working from the bigger end of the bearing.
Sort of work it till it comes out other end takes a bit
Your looking to force the grease between the roller bearings and the inner race
Having never done this it takes a while to you get a knack for doing it
the other grease is there from years of use.
The 'packing' of the clean bearings themselves is the most important part.
The new grease needs to be forced thru the end of the bearing until it lays solidly along side of the rollers and begins to be forced out the other side of the bearing just as your image shows. The bearing must be rotated and pushed into the palm of your hand repeatedly to get it done. Personally, I use my first two fingers to force the grease instead of my palm.
The large amount of grease inside of the hub is overkill. When I was young and overly enthusiastic, I would load the hubs up with extra grease, but it performs no useful function, and makes cleanout a bigger pain the next time repacking needs to be done.
A thin wipe of new grease inside the hub cavity to avoid rusting is sufficient. There must, of course, be some grease at the bushings that carry the drive axle stub at either end of the the spindle itself, but you haven't been clear wether you are going in that deep.
You might be interested in looking at this:
https://www.yotatech.com/forums/f116...ctures-100327/
That gasket looks OK, just grease it lightly on reassembly.
Edit--- I did'nt look closely enough at your truck specifics. I guess you have a straight axle truck. Maybe the spindle lubricator thread might not apply to you.
This is how far in I've gone:
You may want to consider replacing those springs in the near future. When they start to get weak like that they can fail under hard braking, even with the torque arm and the sway bar intact.
Off topic, but food for thought.
All gaskets in the hub are deemed non-reuseable by Toyota but lots of people re-use them. I always recommend replacements.
As stated above pack the bearings with grease correctly and thoroughly. Toyota actually specifys the center resesed cavity of the hub to be filled with grease all the way around. Caution: Over greasing the hub can present incorrect bearing pre-load and hub tourqe.
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
DiggnDeep
09-03-2015 02:45 PM
FS[SouthEast]: Aisin factory hubs, cleaned and lubed
carlspeed
08-23-2015 02:59 PM
