| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Hesitation after warm-up
__________________
1985 4Runner Last edited by martymart909; 11-07-2009 at 06:41 AM. |
#2 (permalink) |
Have you ever changed the fuel filter ?, if not i would try that next.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#3 (permalink) |
I changed the fuel filter today and it still hesitates when it warms up. The 4Runner runs great when it is cold, but as soon as it gets to normal running temperature it hesitates. What would warm up with the engine and then cause hesitation if it was working improperly. All I can think of is a clogged catalytic converter causing excessive back pressure as it heats up. Maybe I am answering my own question, but looking for your suggestions.
__________________
1985 4Runner |
#4 (permalink) | |
Quote:
gNARLS. |
#5 (permalink) |
I have not adjusted the valves since I bought it. What is a valve lash?
__________________
1985 4Runner |
#6 (permalink) | |
Quote:
The valve lash is necessary to allow the valves to have proper seat time while the camshaft is rotating through it's cycle. If the valve lash gets too tight, the valves may not close (seat) completely and your get burnt exhaust valves or fuel mixture overlap during the 4 strokes, causing misfire and lean fire condition. The adjustment is made at each rocker arm with the rocker arm cover off and the engne warmed to normal op temp. It's not real difficult, but does require and thorough understanding of the procedure. You might also have a bad 02 sensor. Typically, hesitation after warm up is related to fuel or fuel pressure, but there are number possibilities - bad ignition coil. gNARLS. Last edited by Gnarly4X; 11-11-2009 at 10:10 AM. |
| Tags |
| 2000, 22re, 4runner, 92, catalytic, cold, converter, hesitates, hesitating, hesitation, lash, runner, tight, valve, warm, warms |
