help on performance problem
I have a "92" 4Runner with a 3.0 liter 5speed tranny with 220,000 miles on it,replaced head gaskets on it and it has no compression on #1 and#6 cylinders at low idle,but does not burn any oil and will still run down the road at 80+ mph and has an audible miss at idle. have replaced all plugs, wires,cap and coil.any ideas on what i need to do to correct it?
Did you put coolant in the engine ??
Pressure test ?/
Why did you replace the head Gaskets ??
Did it get Hot ?/
Check for cracks in the head ??
Just what numbers did you get ??
No compression failed head gasket !!!
Bad valves got the valves between 1 and 6 mixed up
Cracked heads
Rings gone
Cam lobes wiped !!
Pressure test ?/
Did it get Hot ?/
Cracked heads
Rings gone
Cam lobes wiped !!
gixxer
02-18-2016 06:17 PM
