YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-01-2008, 03:17 AM   #1 (permalink)
CTOJOGO's Avatar
Help coverting my '85 xtra cab to efi!!
hey yall. i got a 85 yoder extended cab that was originally efi, but somewhere along the line someone swaped in a carb . i have no idea what year this carb'd motor is, but it is a 22r. i have a 22re out of a 94 pickup in my garage. can i just swap the efi head onto it and have no problems eventhough its a 94 motor? or could i even just swap the intake? what would be the most "foolproof"? i'm not afraid to swap the head, it ain't my first rodeo, but it seems to me that just swapping the intake would be alot faster. thanks yall
CTOJOGO is offline
Sponsored Links
To remove this ad, register today!
Old 09-01-2008, 06:37 AM   #2 (permalink)
csharp100's Avatar
Don't forget the computer and all the sensors, etc to that go along with the new efi.
__________________
84' 4x4, xtra-cab, white, 3" lift, 33's, 22r carb.
csharp100 is offline
Old 09-01-2008, 07:15 AM   #3 (permalink)
CTOJOGO's Avatar
the 85 came with efi, and still has all the wiring and ecu, can i use the older 85 ecu with the newer 94 head or manifold?
CTOJOGO is offline
Old 09-01-2008, 09:29 AM   #4 (permalink)
Staff
Yoda's Avatar
You would need the 85 injectors in the 94 manifold
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 09-01-2008, 10:04 AM   #5 (permalink)
MSR
MSR's Avatar
pull the valve cover and look at the timing chain double row 81-83 if it has a single chain with two chrome links together it's a 84 if only one chrome link on one side and one at the other end its a 85-95 block, the 85-95 block I'd slap the intake on earlier swap whole motor and yes you'll have to use 85 injectors and wiring harness
__________________
www.mikesspecialtyrepair.com
MSR is offline
Old 09-01-2008, 06:04 PM   #6 (permalink)
CTOJOGO's Avatar
my dad has the 94 truck that the 'spare' motor came out of, he pulled it out and put in a 22re from my old '88 without changing anything, and it runs great. his 94 has stock ecu with a complete 88 motor including fuel injectors. so since he didn't have to swap injectors do i? i don't have the injectors from the 85, i bought it about a month ago and it was already carb'd. i do have the ecu and harness from the 88, can i use it with the 94 motor?
kinda off topic, but is there a difference in the 88 22re's? for some reason, from all the yoders i've had, my old 88 ran the best.
CTOJOGO is offline
Old 09-01-2008, 11:41 PM   #7 (permalink)
abecedarian's Avatar
some 411 about the 20r/22r/22re-
http://www.toysport.com/Technical%20...tech_notes.htm
a (short) thread here about injectors-
http://www.yotatech.com/f116/22re-injectors-127606/
some more about 22RE injection-
http://www.well.com/user/mosk/EFI1.htm
__________________
Quote:
Originally Posted by me
If you don't know why people are laughing at you, maybe you don't know yourself as well as you thought you did... or maybe they voted for Obama.
abecedarian is offline
Old 09-02-2008, 06:00 AM   #8 (permalink)
CTOJOGO's Avatar
hey thanks abecedarian for those links. from what i understand, my dad got lucky as hell! but knowing my luck i would've tried the swap and fried my ecm! thats why this site is so awesome. i would've been pissed if i fried my comp. lol.
so all i need to do is find some 85 injectors and put them into my 94 manifold right?
CTOJOGO is offline
Old 09-02-2008, 09:53 AM   #9 (permalink)
if you have the harness from the 85 with the fuel injector connectors, you can compare the connectors to the injectors on the 94- if they plug in without modification, you should be fine since the injectors and connectors are all keyed differently. you can see that here on LCE's page: http://www.toyotacatalog.net/m1webge...spx?Class=1500
the first column has the 4 main injectors Toyota used and they have a diagram of the injector plug. For what it's worth, 200 for a set of new injectors doesn't sound too bad to me.
and some other EFI related stuff from our friend 4Crawler to help you should you have some problems:
throttle position sensor troubleshooting->
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
air flow meter troubleshooting->
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
tons of other 411 from 4Crawler->
http://www.4crawler.com/4x4/CheapTricks/index.shtml
__________________
Old 09-05-2008, 08:48 PM   #10 (permalink)
hmmwv15's Avatar
Shoot, find some used 85 injectors and get them rebuilt, a helluva lot cheaper if you can find used ones for a decent price. Just make sure to wire evrything up RIGHT!!! I bought my 85 with a 95 engine swapped in it and the po did a piss poor job swapping that engine in. Stray/spliced wires wrapped in electrical tape all over the place. Quite a frikkin nightmare if you ask me!
__________________
Sean
What I be drivin':
Weekend/fun rig: 85 4runner in the building process, so far welded rear and a wee bit-o-lift. (thing 1)
Daily Driver: 87 extra cab long bed *deluxe* 2wd p/u
(thing 2)
Is this going to be an Obamanation?
hmmwv15 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Single cab or Xtra cab, and my truck dilema 15.50_STOCK General Vehicle Related Topics (Non Year Related) 8 06-08-2008 11:01 AM
Xtra Cab VS. Normal Cab 0101 84-85 Trucks & 4Runners 16 06-01-2008 07:25 AM
Will bed from '89 Xtra Cab fit '88 Xtra Cab? rdlsz24 86-95 Trucks & 4Runners 10 05-26-2008 05:29 PM
single cab, xtra cab, quad cab slisdexia General Vehicle Related Topics (Non Year Related) 15 05-12-2008 11:55 PM
Xtra cab or regular cab frame dixieduck 86-95 Trucks & 4Runners 4 01-13-2006 12:19 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
