HELP!!! 85 pickup keeps dieing! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-31-2009, 12:45 PM   #1 (permalink)
scott_co65's Avatar
Angry HELP!!! 85 pickup keeps dieing!
Ok i've posted something similar to this be4 but now i have found a different problem. The issue is that i can't keep the battery charged on my 85 pickup 22r. Tried alternator, was fine, checked all fuses, and replaced the old battery with a brand new one. Now last night i decided to return the battery with a new one. After puting it back on last night i decided not to start it so i could see if something was running it down with the truck off. So i gave the horn a beep and turned the lights on to make sure it was hooked up. Waited about 12 hours and now its completely dead again. Any ideas of what may be wrong or running while the truck is off??? By the way this is completly stock truck. PLEASE HELP!!!
scott_co65 is offline
Old 10-31-2009, 01:37 PM   #2 (permalink)
Gnarly4X's Avatar
Quote:
Well, you've got parasitic drain on the battery. You need to locate the drain or short, and in my experience that can be a pisser!
Start by checking with a VOM at the battery terminal and hot lead clamp to find out how much current is draining. To measure amps you need to read in series with the battery and cable. So you need to remove the clamp and probe between the terminal post and the clamp. Depending on how many amps or milliamps is draining the battery, you can get some idea as to what the source might be.
gNARLs.
Gnarly4X is offline
Old 10-31-2009, 02:12 PM   #3 (permalink)
22RUCRAZY's Avatar
What was the last thing you replaced , may be a possible . I had a slightly cut ignition wire draining my bat , Also make sure you have atleast 2 good grounds
GOODLUCK
22RUCRAZY is offline
Tags
85, battery, help, pickup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
