| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
heater core replacement?
__________________
87 longbed, 3rz, tacoma dash, bobbed, SAS'ed, gears and more. My build----HERE More web wheeling- Just getting started so come join us Asphaltsux |
#2 (permalink) |
It's a lot easier than on many vehicles.
Aftermarket should be as good as OEM, and waaay cheaper.
__________________
- - As seen in FOUR WHEELEER magazine July 2006, OFF-ROAD magazine Feb 2007 - - '84 4Runner SR5 - ARBed 5.29s F&R, 4.7 t-case, drv train lift, Chevys, hi-steer, 30 spl Longs '80 something Toy P/U, Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH350 L/U w/700R4 low gearset, dual tanks, dual batterys |
#3 (permalink) |
Staff
If I remember correctly, there are 2 extension tubes that pass through the firewall and connect to the actual heater core. Have done 2 some time ago (1 last year)
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
#4 (permalink) |
ok heres the thing i pinched the tubes coming out of the firewall and kinked one. the hose was stuck on and i thought i could grab it and twist ti to brake it loose and smashed it. Rather then bend it back and have a weak line that would bother me forever i figure replace it.Is that not the heater core then? On VW's (what i usually work on ) the heater core is right behind the firewall in the heater box and the lines run through it. I need to replace both of them now cause i pinched the other one off so the oil that was in there wouldnt leak all over the new paint while im working on it or swapping it.
__________________
#5 (permalink) |
I'm in the process of tearing down an '88, and what I have seen/learned is that to get to the heater core, the dash has to come out. The heater core is in front of the center part of the instrument panel and it is part of the whole HVAC system. The heater core itself is inside a plastic housing that makes up the HVAC system. If you are removing the dash pad, keep in mind there is a fastener behind the far right/passenger's side dash vent; you have to remove the dash vent to get to it. There is another fastener in the middle of the dash pad, accessible from underneath the dash. Finally there is one at the left end of the dash pad underneath the instrumet cluster. Hope this helps and that this is the information you are looking for.
#6 (permalink) |
Thanks, I will be pulling everything out of the interior(all i have is that dash to go) and replacing it. I think this is well worth it to replace while its out.
I have never even attemped the dash removal on a toyota.I know the heater core on a vw is about a 10hour job to do.
__________________
#7 (permalink) | |
Quote:
__________________
Toyota Master Diagnostic Technician "MDT" 1998 Toyota Tacoma TRD V6 4WD 5 SPD 1998 Chevrolet K1500 1999 Toyota Camry 2003 Toyota Highlander 4WD 2007 KTM 85SX 17/14 2006 KTM 300XC-W 2005 KTM 65SX 2004 Kawasaki KLX 110 2003 Honda XR50 2002 Yamaha TTR 125L 2002 Kawasaki KLR650 2002 Suzuki Eiger 400 4WD 2004 Cargomate<--link GeePaw® Racing<--link Last edited by toyota_mdt_tech; 11-27-2006 at 09:36 AM. |
#8 (permalink) |
Thanks,I planned on replacing it anyways.The dash will be out to replace the pad and heater control and all the heater parts. this one is different then my 87.My 87 had strong hoses coming out and thats how i got the hoses off.I didnt get any leaks by twisting the hose off but it wasnt seazed on like this one.Oh well i guess when i go to the dealer for the heater core i will get all the clips clamps and o rings. My goal when this is all said and done is to have a "new 85 4runner" So far so good. in about a month i will have a new one.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| heater core? | 86toysr5 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-13-2007 06:37 PM |
| Removing heater core | FSRBIKER | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 01-02-2005 08:44 PM |
| Heater core replacement | the_supernerd | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-08-2004 10:31 AM |
| heater core replacement in first gen | wifesaysimadumbass | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 03-15-2004 08:52 PM |
| Heater Core replacement...Any clues, tricks, tips? | porkracer | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 04-29-2003 05:17 PM |
