| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
headlights work, but NO tail, licenceplate, dash, or corner lights
#2 (permalink) |
Staff
my dash lights stopped working when my tail lights fuse went... but since you said you checked the fuses, idk what to tell you.
__________________
94 4runenr: all the good stuff....... 89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs. 81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s pacific-crawlers.com For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :) |
#3 (permalink) |
Check the grounds on those lights. Headlights are grounded via the headlight combo switch but the rest of the lights have separate ground wires near each light. Tail light fuse is what controls them. Have you recently installed a radio or other electronics? If so, check that install out, that may be the cause of the problem, it was in my '85.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
Try pulling the instrment out, because on the earlier models if a dashlight bulb goes out the whole circut is comprimised, like x-mas tree lihgts.
#5 (permalink) |
yeah, i put a radio in it about a month ago but used its own ground and the wires that were already ran there. the radio still works too....could it be in the headlight switch itself?
and just to be sure there are two panels of fuses, one in the cab on the left and one in the engine bay near the battery, right? |
#6 (permalink) |
When I installed a new radio, using the wires that were already there, I had problems with the tail lights not working. Radio worked fine, but the tail lights did not. I think the problem was the backlight or switched power wires for the radio. I did end up running all new wiring for the radio and only made use of the 8 stock speaker wires.
Check the headlight switch, for sure.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Aren't the dash lights and trailer lights supposed to work?? | Texas_Ace | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 05-29-2007 10:42 AM |
| corner lights and tail lights gone!! | Travisfab | General Electrical & Lighting Related Topics | 6 | 05-21-2007 07:35 AM |
| 3rd Gen 4Runner tail lights, 1 front corner light | One More Time | The Classifieds GraveYard | 2 | 03-12-2007 03:22 PM |
| dash lights, marker lights and taillights dont work | nbrooks | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-24-2005 03:25 PM |
| Tail lights, corner lights, and gauges out. Please help. | Juggalo | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-26-2004 01:16 AM |
