Head Gasket?!? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-22-2009, 10:47 AM   #1 (permalink)
TRD deerslaya00's Avatar
Head Gasket?!?
ok guys so last weekend i purchased a truck wich i thought i had made a really good deal on... an 85 ext cab efi no rust in body or frame. test drove it for probably 2 miles down the road and back, everything was gold on it... so i get it home and yesterday on the way to my buddys shop to get it inspected it starts running hot, i let it cool off and make it to the shop without overheating it and realize it was low on coolant, so i fill it up and shes good to go drove it to work 30 mins away last night no problems and home no problems, today it started running warm again and when i get to where im going it was low on coolant again, i down see where it could be leaking out the radiator and when i bought the truck guy claimed it had old gas in it wich was beleiveable it hadnt been on the road for a while and it smoked, i put 3 gallons of 93 in it and the little bit of smoking cleared up. any suggestions???
TRD deerslaya00 is offline
Old 10-22-2009, 06:39 PM   #2 (permalink)
aalan's Avatar
look at your plugs. If you have coolant going in one of the cylinders they will tell the tale. Check your oil level. Does it look like chocolate milk? Or, do you have too much oil seemingly? It could be going there. That's where mine was going. But it really didn't show until it got really bad.
__________________
84 4runner
22r carb.
One Owner
aalan is offline
Old 10-22-2009, 06:43 PM   #3 (permalink)
Kiroshu's Avatar
First thing is check ur oil and see if its milky or any white in it. If so then your looking at a new headgasket. Look very very closely for leaks. It may just be leaking out of a hose or pipe and you can replace and good to go. Look further into it.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 10-23-2009, 07:25 AM   #4 (permalink)
Etype R's Avatar
My 85 4runner started blowing white smoke less then a week after buying it. I quickly parked it and ordered up a head gasket, and intake gasket set. Spent a entire Saturday replacing those gaskets. I believe it was one of the intake gaskets that was leaking, not the head gasket. The old gasket material did not appear to be fully removed last time the HG was done.
If you have heavy white smoke coming out of your exhaust, its a coolant leak in the system. Also check your oil like others have said.
__________________
1985 Toyota 4Runner - Full SR5 package - 4 inch lift - 35" tires
Etype R is offline
Old 10-23-2009, 08:11 AM   #5 (permalink)
92 TOY's Avatar
All of the above and check the timing chain.
want to see what a mess a broken guide can make when the chain digs into the cover, check my thread.
pull the valve cover off. I don't know how water could hide it's evidence from you if you look there but also you will be able to view the chain.
__________________
1992 4x4 shortbed /22re/auto/192,000 miles--original owner(rebuild in process)
1988 SR5 4runner /V6/5 speed/248,000 miles/bought April 2009/***UNDER CONSTRUCTION***
2006 SR5 4runner (the wife's)....still being paid for...
>>>>***Check out My SLOOOOOOW Re-build Thread***<<<<
http://www.yotatech.com/f116/92-toy-...-start-188472/
92 TOY is offline
Old 10-23-2009, 12:50 PM   #6 (permalink)
i ordered the gasket kit after talking to my buddy whos a mechanic were gunna stay on the safe side and just replace the gaskets
__________________
01 taco 6 and 33's
85 ext cab EFI. 4 and 33's
S T R E T C H E D O U T
kennels
Tags
1988, 4runner, 92, check, coolant, gasket, head, leaking, oil, radiator, smokes, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
