| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Hard Starting
#2 (permalink) | ||
the fsm points to the ac signal circuit for slow cranking.
http://www.ncttora.com/fsm/1990-1995...e/troubles.pdf
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 233k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 235k on the clock. It's becoming an addiction. |
#3 (permalink) |
the tab attached is for a 3vz engine not the 22r and what is the ac signal circuit? thanks team 420
#4 (permalink) |
have you pulled the plugs to see if it will turn over faster, and check your ground from frame to motor.
__________________
85 toyota rancho lift 33 in tires on 15X8 steel 270 lift cam and flat tops Those who do not learn from history are doomed to repeat it, or they're showing up their friends. Again! |
