Grease for knuckle/bearings etc... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-27-2009, 10:23 AM   #1 (permalink)
I'm going to be putting back my knuckles and all that stuff soon, but I need to get some grease to pack all the appropriate stuff.
Molybdenum disulphide lithium base grease.
Sometimes it refers to this as a general MP grease and sometimes is says to use it specifically. Should I be concerned about a different kinds of greases or just get this and use it as a general MP grease (unless otherwise specified in the FSM)?
live4soccer7 is offline
Old 10-27-2009, 10:43 AM   #2 (permalink)
Wardamneagle's Avatar
You need to use a moly fortified grease for the knuckles (and trunion bearings, although opinions vary on this). You should not use this grease on the high-speed wheel bearings.
I like synthetics so I used Amsoil moly-fortified synthetic for the knuckles and trunions bearings and Mobil 1 (red) synthetic for the wheel bearings. Many people use the Valvoline moly-fortified synthetic for the knuckles as it can normally be found locally.
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Wardamneagle is offline
Old 10-27-2009, 12:18 PM   #3 (permalink)
Which of the ams do you use? Not quite seeing one that states what you said. I use amsoil in my car and love the stuff, so I think I'll stick with them. Thanks for the help.
Also, how many tubes do you think should get the job done for both sides, with some to spare?
http://www.amsoil.com/a/Synthetic-Grease
Also, is this the stuff you are talking about for the wheel bearings?
http://www.amazon.com/Mobil-Syntheti.../dp/B00085F4JO
Old 10-27-2009, 07:22 PM   #4 (permalink)
anyone know about how much of this I need?
Old 10-27-2009, 08:18 PM   #5 (permalink)
Anyone know which grease to get to pack the knuckles? I want to get amsoil, but I'm not sure which to get.
This is the last thing I need to order up.
Old 10-28-2009, 07:13 AM   #6 (permalink)
Synthetic Heavy-Duty Grease NLGI #2.
http://www.amsoil.com/storefront/ghd.aspx
6 tubes total will be enough to have at least 1 tube left over.
Yes, that's the correct Mobile 1. You wouldn't need more than 1 tube for the wheel bearings. You could also use one of the non-moly Amsoils as well such as:
http://www.amsoil.com/storefront/glc.aspx
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Old 11-01-2009, 10:39 AM   #7 (permalink)
Also, I've got one more question. The oil for the differential when I have to fill it back up. I'd like to get some ams as well. What kind and how much? I remember looking in the FSM before and it may have told me how much, but I wasn't sure on the specific kind.
Old 11-01-2009, 10:57 AM   #8 (permalink)
Any of their 75W-90 or 80W-90 gear oils will work:
http://www.amsoil.com/a/synthetic-gear-oil
I use Redline Synthetic for the diffs and manual trans but I doubt that there's any reason not to use the Amsoil. Just to confuse things, I use Amsoil synthetic ATF for automatic transmissions and Mobile 1 for all the engines. Why? Even I don't remember.
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Old 11-01-2009, 11:34 AM   #9 (permalink)
Outsane's Avatar
Send a message via ICQ to Outsane Send a message via AIM to Outsane
Damn, really six tubes?
__________________
1984 4runner -
Photography
Outsane is offline
Old 11-01-2009, 11:52 AM   #10 (permalink)
Gnarly4X's Avatar
Quote:
You do NOT need to pack the knuckle full of grease. Just hand pack and rub lots of grease in the birf joint. Any kind of moly grease will work fine -- your knuckles will not know the difference.
gNARLS.
Gnarly4X is online now
Old 11-01-2009, 11:57 AM   #11 (permalink)
Gnarly4X's Avatar
Quote:
Unless you live in extreme cold climate, any API GL-5 hypoid gear oil will be fine. If you want to go to the extra cost and "feel better", you can use any synthetic. Your diffs won't know the difference -- unless your are running posi-traction type 3rd members.
For the manual tranny and t-case you can't beat Redline!!
gNARLS.
Old 11-01-2009, 01:32 PM   #12 (permalink)
No it doesn't take 6 tubes but I couldn't remember if 2 tubes per side was enough or not and he said that he wanted some left over. Maybe 4 or 5 tubes would have been a better suggestion.
Agree that the knuckles shouldn't be full. Pack the birfields entirely full and then fill the knuckles about 3/4 full or maybe a little less.
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Old 11-01-2009, 01:39 PM   #13 (permalink)
Outsane's Avatar
well I guess I need three more tubes...
I only got two tubes of Amsoil NLG1 #1
__________________
1984 4runner -
Photography
Outsane is offline
Old 11-01-2009, 11:10 PM   #14 (permalink)
Just curious, but why do you use redline over anything else. It seems you are pretty set on it. I've heard the MT is great for trannies, but I'm just wondering your point of view on it. Maybe I'll switch over from ams (it's what i've used in my car tranny, diff and engine).
Old 11-01-2009, 11:18 PM   #15 (permalink)
kinzer's Avatar
personally i use marine grease for everything and never have a problem, iv replaced and removed too many birfs and droped the diff soooo many times if found it not worth it to use speacial synthetic greases and oils or even fill the knuckles, i bought a 5 gallon bucket of gl-5 and use that in all my drivetrain.
__________________
They call me the "Short Bus"
89 pickup SR5 3VZ-E 5 speed 4X4
5" HD trail gear sas | rock sliders | u bolt flip kit | 6" shackles | 38X12.50 TSL's | led rock lights | 5.29's
dual t-cases 2.28 and 4.70 | welded front and aussie locked rear | bud built flat belly skid
marlin crawler rear bumper | trail-gear front bumper | x-plod amp & kicker cvr 12
Flowmaster | K&N system | 125" wheel base | cb
http://www.youtube.com/watch?v=yQbF4ThlNEI
Quote:
Originally Posted by Matt16 View Post
but if you only got 3" to start with, 5" is huge...
kinzer is offline
Old 11-02-2009, 12:24 AM   #16 (permalink)
You need NLGI #2 (multi-purpose for the wheel bearings and moly-fortified fortified for the knuckles).
I guess I have read too many recommendations for Redline synthetic in manual transmissions, transfer cases, and differentials to ignore. Again, I don't think you can go wrong with Amsoil or Mobil 1 products either. FWIW, I haven't seen it recommended for automatic transmissions. I used Amsoil ATF in my Land Cruiser transmission but it was a toss up between that and Mobil 1.
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Old 11-02-2009, 12:58 AM   #17 (permalink)
Gnarly4X's Avatar
The last 5-speed I had rebuilt shifted nice and tight. My tranny shop said the "notchy" shifting would smooth out, but it didn't seem to go away. They offered to pull it down and replace the brand of synchros. It had a just tad of "notchy" shifting.... just a little syncho lag going from gear to gear, especially 1st, 2nd, 3rd. I put in Redline MT-90 and was totally amazed at how smooth it shifted. I would highly recommend it. I suppose Amsoil will do the same thing.
Note: if you have your manual tranny rebuilt, always request that the shop use nothing but Toyota Factory synchros. The aftermarket synchros have an inconsistent alloy metallurgy that makes the for un-smooth shifts. This info goes back about 10 years, so I don't know what my tranny shop would say today.
gNARLS
Old 11-02-2009, 06:36 AM   #18 (permalink)
good information thanks
Tags
4runner, 85, amsoil, bearings, grease, greasing, knuckle, knuckles, mobil, moly, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
