Fuel sender thingy
Old 08-23-2016, 09:11 PM
mikeyd6789's Avatar
Fuel sender thingy
What options do I have to get another fuel pickup from inside the tank? Mine is rusted to pieces. While it still functions, it's only a matter of time before it fails. Should I try to make one? Any suggestions?
Old 08-25-2016, 11:15 PM
bklf7's Avatar
I bought one off eBay. I'd check there first. It was pricey though
Old 08-26-2016, 12:19 AM
wyoming9's Avatar
It is called fuel pump bracket
Depending how old of a vehicle you might still be able to get it from your Toyota dealer.
Just be aware the different tanks take different ones .
If you have the fabrication skills to make one in time alone most likely to buy one
Old 09-20-2016, 03:00 PM
acudadude's Avatar
ebay is your friend
Old 10-06-2016, 01:42 AM
Beakness's Avatar
I just had to replace mine, beware that even for the same model year there are different parts based on trim level, the only way to be truly certain that you have the right part is to go to the dealer with your VIN #, cost me $225!
Old 03-11-2017, 05:59 PM
Neutrino's Avatar
Did you end up finding one?
Old 03-13-2017, 05:33 AM
jammin962's Avatar
Just replaced mine, different part number than yours though... Call dealer with vin and ask them to give you correct part number then go on ebay. I got mine for about $160 dealer was over $200.
Good luck I had to drill 4 of the 7 bolts out after they broke! gotta love the rust
geoduke
03-25-2016 05:30 PM
jiggseob
03-23-2016 04:20 AM
Dana Pereau
11-18-2002 05:18 PM
Quick Reply: Fuel sender thingy
